Previous in Forum: Effect Of Altitude On Pump Performance   Next in Forum: Reynolds Number For One Dimensional Oscillating Flow Through Pipe
Hogger Ejector Air Cooled Condenser
01/16/2013 1:38 AM
I am trying to understand Air Cooled Condenser P&I diagram, in which I found their is hogger ejector connected to CST, I couldn't able to understand the purpose of Hogger Ejector in ACC, pl. let me know function of the same.
Pathfinder Tags: HOGGER EJECTOR
Re: HOGGER EJECTOR AIR COOLED CONDENSER
01/16/2013 5:29 AM
Good Answers: 445
Re: Hogger Ejector Air Cooled Condenser
01/17/2013 12:08 PM
Actually I asked the very same question when I was a co-op student crawling around my first generating station. As JP stated above, the purpose of an ejector is to remove condensables (water vapor) and noncondensables (gases) from the condenser space.
The hogger is a high volume device, moderate vacuum device. It's specific job is to quickly evacuate the condenser and the back-end of the LP (Low Pressure) turbine before the plant starts up after any prolonged shutdown.
You will also notice that there is a vacuum pump on the condenser as well. This is a low volume, high vacuum pump that provides the very high vacuum that is required for proper operation of the turbine. It operates whenever the plant is in operation, removing any noncondensables that have found their way into the feedwater.
Register to Reply 2 comments
