Previous in Forum: Polymerization   Next in Forum: Care To Be Taken After Pickling of a HR Steel Coil?
India - Member - New Member Engineering Fields - Electrical Engineering - New Member Technical Fields - Technical Writing - New Member
Hot Rolled Steel Coil Pickling Standards
01/20/2013 8:48 AM
Suppose 23t(avg wt.) hot rolled coils(end user- auto industry as HRPO) are being pickled in a push pull type pickling line. After pickling of how many coils, the HCL acid of acid tank of that pickling line should be replaced completely to have better surface quality and less defects? is there any thumb rule or formula to be followed?
Re: Hot Rolled Steel coil Pickling standards
01/20/2013 8:58 AM
You would have to do a titration of the tank and follow you chemical suppliers recommendations.
01/20/2013 11:14 AM
I wanted to mean replacement of HCl acid as its concentration get decreased gradually with each coil get pickled and thus oxide removal capacity of acid from hr coil surface also get decreased.
01/20/2013 11:23 AM
See #1
You might try a pH meter.
Do you not have a process engineer, or someone who knows something about quality control?
01/20/2013 11:52 AM
You have to titrate, to measure acid concentration, free acid, and iron % and PH. There is no rule of thumb. Your chemical supplier will have parameters. We pickle steel as part of pretreatment before coating in our plant, we change tank maybe once every year (to remove contaminates). We titrate twice daily and adjust concentration accordingly.
If you don't titrate and just want to dump tank every so often, so be it, it's going to get expensive.
<edit> A pickling tank is a mixture of HCL and water, you don't just dump it when concentrations get low, titrations will tell you when to add more HCL.
Contact your HCL acid supplier, they will have the info you need.
01/20/2013 11:14 AM
How about just changing it when it takes on an "off" odor?
JPool (2); lyn (2); sidhu16 (1)
