Previous in Forum: LED Light Bulb   Next in Forum: Earthed and Unearthed Cable
What Is the Difference Between Bonding, Grounding and Earthing?
01/21/2013 6:03 PM
Good Answers: 50
Re: What is the difference between Bonding, Grounding and Earthing?
01/21/2013 6:58 PM
The server does not respond to this link.
ignator
ignator -
01/21/2013 8:10 PM
Try again! It does for me!
Good Answers: 50
01/22/2013 2:09 AM
I don't know what the problem is but this is the response I get:
The requested URL could not be retrieved
While trying to retrieve the URL: http://electrical-engineering-portal.com/what-is-the-difference-between-bonding-grounding-and-earthing
The following error was encountered:
We can not connect to the server you have requested.
This means that:
  • The server might be busy at this time.
  • The server is not reachable.
Please try later to see if you can go through.
Generated Tue, 22 Jan 2013 08:16:07 GMT by (Application and Content Networking System Software 5.1.15)
It's not asking to use Java or cookies, which I control with firefox 12.
ignator
ignator -
01/22/2013 4:01 AM
Try different browser.
It is still all good for me!
01/22/2013 7:30 AM
This website relates to an engineering advice page from India, and is written in somewhat Indian English. There are also some statements with which one may disagree:
"Earthing means connecting the dead part (it means the part which does not carries current under normal condition) to the earth for example electrical equipment's frames, enclosures, supports etc."
"Grounding means connecting the live part (it means the part which carries current under normal condition) to the earth for example neutral of power transformer."
01/23/2013 12:07 PM
Yah...I use "grounding" all of the time, but my main keeps tripping. I wonder why?
But it keeps me from getting electrocuted...what with no power and all.
common knowledge...less common than common sense
02/06/2013 3:30 PM
Grounding is connecting of equipment to the Earth via a grounding electrode.
This consists only of the actual rod/plate/pipe/conductor in the ground/concrete and the conductor attached to it.
Any other conductors which attach to this "ground" are considered bonded to ground, but never grounded themselves.
Earthing is not a common term I am familiar with. I find it used most often by people not familiar with the descriptions of grounding and bonding.
But I am a Journeyman Electrician/Instrument Technician in Canada, your country may have a different description of these terms.
Register to Reply 7 comments
IdeaSmith (2); ignator (2); Phillyblunz (1); phph001 (1); The.Tinkerer (1)
