Previous in Forum: turns of thread gauge formula   Next in Forum: High Magnetite Consumption
Faro Arm
01/23/2013 3:15 AM
Am using a Edge faro arm and it does not seem to hold the tolerences that I need. I have calibrated using the 3mm probe and also my laser scan. The tooling balls on the platform fixture do not give me repeatable results. Any thoughts?
Re: Faro Arm
01/23/2013 5:36 AM
CR4 ADMIN: Deleted Post
Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Re: Faro Arm
01/23/2013 9:59 AM
Contact Faro. You may also want somebody to review your measurement technique in using this instrument. It is easy to work too fast, lean on a reference or not actually measure the same point twice in so many ways that only a person witnessing your technique can help you.
Re: Faro Arm
01/23/2013 12:22 PM
Maybe you should be using checking balls and not tooling balls for measurements.
Do your "tooling" balls have a reference shoulder.
And, again, did you contact the supplier?
Location: Hamilton Ontario - Canada. 43º16'10.95"N 79º51'12.14"W
Re: Faro Arm
01/23/2013 4:33 PM
Are you using the ball to calibrate, or the point method? I find the point method far more repeatable, and more accurate, using our old Faro Silver arm. When measuring the tooling balls, are you measuring them as a sphere or just a circle? Might be time to cough up some $$ for a CMM.
Ian
Re: Faro Arm
01/27/2013 11:55 PM
I had a CMM, but the new parts that I need to measure would not fit on it. I did recieve an update from Solid works and it has helped.
Re: Faro Arm
04/23/2013 10:30 AM
Donovan,
What size tooling ball are you actually using? Do you know if you are supposed to be using the center of the ball or the center of the top of the busing that it fits in?
Give us a call if you need additional assistance, we work on similar fixtures when we provide measurement services and build custom probes for Faro Arms that need to be calibrated. www.metrologyworks.com or 816-650-2266.
Thanks,
MetrologyWorks
Register to Reply 6 comments
catisred (1); Donovan (1); lyn (1); MetrologyWorks (1); QCIan (1); redfred (1)
