Here's a question for you -
In our current project we use an electromagnet - about 400 Gauss. We were taking measurements of residual magnetism on the magnet and the steel plate that is attaches to.
We placed the steel plate on the magnet and energized it, took a bunch of measurements, then removed the power and took more measurements. There was very little residual magnetism - on the order of 3 Gauss.
Yet, when I tried to remove the plate from the magnet it was stuck. It took two hands to pry it off.
Once removed, if you place the plate back on the magnet, there is no attraction - so it's not a case of the magnet or plate remaining magnetized after the power was removed. (the magnetic field on the magnet was 3 G, the steel <1G).
So, the question is - why does the steel plate stick to the magnet after the power is removed, and why doesn't it still stick after you separate the two?
Inquiring minds want to know.
