Previous in Forum: Buckling of a Beam of Circular Cross Section   Next in Forum: Suggest Me Software to Use?
Temperature Requirement of Concrete Curing Compound
01/28/2013 1:33 AM
What is the maximum concrete temperature at the time of application of curing compound?In case the concrete temperature rise due to hydration, will the layer (wax like) will be melted?Thanks
Re: Temperature requirement of concrete curing compound
01/28/2013 6:33 AM
After reading several TDS's for wax based curing compounds, I can find no maximum application temperature just a minimum (4 C). Do you have the manufacturer and description of the particular compound you are considering? If you are concerned about wax application, you can use resin based compounds.
http://www.daytonsuperior.com/Artifacts/Section%2005%20-%20Curing%20Compounds.pdf
A call to the manufacturer may be the way to get your answer.
01/28/2013 6:44 AM
After giving your question some more thought, I used a wax base compound in the past, the wax was already in a liquid state, can't melt. There were warnings about letting it get to cold (40 F, 4 C) because wax would solidify.
Register to Reply 2 comments
