Previous in Forum: Research Study on Circuit Pads   Next in Forum: Developing HF Inductors / XFRs for DC-DC Converters
How To Deal With Water Contamination in Oil
02/08/2013 11:03 AM
Water is widely considered as the second most destructive contamination to a lube system, after particulate contamination. Identify where the water has come from and find solutions to maintain a water level as low as possible. For more information on water in oil contamination visit http://www.kittiwake.com/sites/default/files/3%20-%20Water%20Contamination%20in%20Oil%20Dec12_0.pdf
Re: How To Deal With Water Contamination in Oil
02/08/2013 11:52 AM
Please see CR4 rules of conduct.
Item #9: Aside from one limited posting in the Commercial Space forum, advertising of any kind is not allowed.
02/23/2013 1:08 PM
I personally see it as a oil contaamination of water. We are using and will keep on using old designs of equipment and things that use water for cooling and the way they designed cooling ports and journal for water to flow allows the mix to happen.
Why not redesign to prevent the problem but that would get rid of a lot of job making repair parts I guess.
Register to Reply 2 comments
