Previous in Forum: Null Meter   Next in Forum: CT Ratios Calculation
PMG Issue on GEC. Alsthom Large Machines Limited..
02/12/2013 11:06 AM
One of our steam Turbine driven Alsthom AC generator's PMG has got damaged. Nearly Six of the magnets have been dislodge from the rotor. Can any body tell me where can i repair my PMG or get an exact replacement.
The specs for the PMG are
270 PMG 101 590A451
Type: 19/40
Rating
Open circuit volts: Not to exceed 200 V
Frequency: 200 Hz
Phases Single
Speed 1500rpm
Over speed 2250rpm
Ceiling Rating 180V 10 Amps
Power Factor .9
Air Gap 1.5mm
The specifications of the Generator on which the PMG is installed.
AC GENERATOR, 3.3KV, 2050KVA, 1640KW, 360A, 0.8PF, 50Hz, 1500RPM, IP:22, INSULATION CLASS: F,
ALTITUDE: 1000 M, HUMIDITY: 0.54, AMBIENT TEMP: 50, IC: 01,
MAX OVERSPEED: 1800RPM, WGHT: 6420 KG,
FRAME: GP500 / 1250 Q,
SPECIFICATION NO: BS5000 - 99, S/N: E-44350601,
Mfg Year. 1990,
Make: GEC. Alsthom Large Machines Limited.
Re: PMG issue on GEC. Alsthom Large Machines Limited..
02/12/2013 11:11 AM
