Previous in Forum: Which Turbine Work Done Maximum?   Next in Forum: Bypass Valve for Equipment in Piping
Seeking Clarification of Resonance Frequency Equation
02/13/2013 10:08 AM
Dear Sir / Madam,
I have read through SMACNA's HVAC Systems - Duct Design, chapter 11 section 5 Insertion Loss External Duct Lagging.
I have a problem with equation 11-81 to determine the resonance frequency, fr (Hz), associated with the interaction between the duct wall and outer covering as below :
fr = 156 [ (P2/P1 + M2/M1) x (P1/M2) x S]1/2
where P1 is the perimeter of the duct (inches), P2 is the perimeter of the outer covering (inches), M, is the mass per unit area of the duct (lb/ft2), and M2 is the mass per unit area of the outer covering (lb/ft2). S is the cross-section area (in2) of the absorbent material.
It seems like the equation is not correct. Could somebody advise me.
Thank you.
Re: Seeking Clarification of Resonance Frequency Equation
02/13/2013 3:52 PM
Why not speak directly to the publisher of the text? I'm sure they would be greatful if you have actually found a flaw in their work.
Sheet Metal and Air Conditioning Contractors' National Association ...
02/14/2013 11:56 AM
Seems like missing info to me, too.
Left of the = you have Hz which is cycles/sec. Right of the = you have lengths and weights (masses). How these reduce to cycles per second is not readily evident.
