Previous in Forum: Current Transformer Secondary Current in 3 Phase 4-Wire   Next in Forum: Electricity Consumption Usually Increases Due to the Below
Sensor Question
02/16/2013 8:12 AM
how can i check generator sensor
Re: sensor
02/16/2013 9:06 AM
Since you asked such an imprecise question, you cannot check any sensor.
Re: sensor
02/16/2013 9:30 AM
Check sensor with generator off.
Check sensor with generator on.
Compare the different readings.
If readings same, sensor bad.
If readings different, sensor good.
Re: sensor
02/16/2013 9:44 AM
Sensor may be good but display is bad.
Sensor may not have a display.
Item sensor measures may really not change with generator running a brief interval.
The OP doesn't even understand that telling us what the sensor measures is important. The OP cannot check any sensor.
Re: sensor
02/16/2013 9:46 AM
Humor him.
Re: Sensor Question
02/18/2013 3:21 PM
What type of a sensor do you want to check it !?.
caeser (1); lyn (2); redfred (2)
