Previous in Forum: Magazine Renewal   Next in Forum: Computer Challenged
9 comments
How Much LN Can Shrink the Iron
02/19/2013 11:02 AM
can any one tell me what diameter i have, if i dip a 14mm diameter of iron piece in Liquid Nitrogen?
Pathfinder Tags: liquid nitrogen
Good Answers: 918
Re: how much LN can shrink the iron
02/19/2013 11:09 AM
Look up the linear thermal coefficient of expansion for cast iron. It is something like 10.8 X 10-6 m/m °C.
So find the difference in temperature in degrees C from its initial state to its final sate (immersed in the liquid nitrogen). Multiply that number of degrees by the coefficient of expansion and you are done.
Good Answers: 918
02/19/2013 11:39 AM
I should add, the result in my first post must be multiplied by the dimension of the iron object.
02/19/2013 11:14 AM
< 14mm... IF your 14mm rod is not already at -200°C or so.
Is the volume on LN2 sufficient to immerse this iron piece before it boils away?
02/19/2013 11:17 AM
Very roughly 13.7mm (assuming, among other things, that it measures 14mm at room temperature).
02/19/2013 11:50 AM
This sounds too much like homework to me.
Here is a site that will give you lots of information:
Online Materials Information Resource - MatWeb
02/19/2013 12:07 PM
This sounds like a marvelous technique for testing if the piece of iron has any mechanical imperfections and stress points. The thermal conductivity of iron is relatively poor for a metal, particularly at room temperature (300K). Immersing room temperature iron into LN2 at 40K will cause the outside of the iron to contract in size much faster than the center core of the iron.
Good Answers: 444
Re: How Much LN Can Shrink the Iron
02/19/2013 1:28 PM
I'm just a EE so correct me if I'm wrong, but isn't this a volume or area, as opposed to a linear coefficient of expansion problem? OP only gave us an area dimension and didn't mention the shape (wire, rod, washer, shim, sphere, etc.). According to Wikipedia the linear coefficient is 1/3, and the area coefficient is 2/3, that of the volume coefficient.
So which one do we use?
Good Answers: 918
02/19/2013 1:35 PM
I think it is linear and in all directions. So, if you had a steel ball and lowered its temperature it would shrink in all dimensions uniformly based on its coefficient of expansion.
02/19/2013 1:47 PM
Since Iron has a body centered cubic crystal structure the volumetric expansion coefficient (β) will be three times the linear coefficient (α). Now depending on impurities and the shape this could just simply shrink as the OP wishes or internal stresses from rapid cooling could crack or shatter things as I proposed earlier.
Register to Reply 9 comments
Anonymous Hero (3); Doorman (1); JohnDG (1); lyn (1); RAMConsult (1); redfred (2)
