Previous in Forum: Specification for Microfiber Cleaning Cloths   Next in Forum: Best Garden Tools Manufacturers India
Quantity of Electrodes per Joint Made
02/22/2013 3:01 AM
Gud morning guys, can someone help me with the formula on 'how to calculate the number of welding electrodes required for pipe weld'? ;joint design angle is 371/2 degree and root gap is 1/8 inches, pipe wall thickness is 5mm.
Peter Iyere
Re: Quantity of Electrodes per Joint Made
02/22/2013 10:08 AM
Information please. Is this SMAW? Electrode size,filler material? Thickness? Applicable code?
I went to Texas A&M, I am proud to be an Aggee. Proud to be an Aggey, Proud to be an Agie.............Proud to have gone to Texas A&M.
02/23/2013 10:49 AM
Thanks for the requested info. Welding process=SMAW Electrode size: 3.2mm filler matl: E 6010 , & 7010 Material thickness: 2'' sch. 80 Applicable Code: ASME B31.3
Peter Iyere
02/22/2013 1:16 PM
Run one rod, see how far you get. From that, you can figure the number of rods required for the job.
Don't know of a formula, and different welders consume differing amounts of rod, depending on technique.
Alternate: ask your welder.
02/23/2013 12:18 AM
Register to Reply 4 comments
lyn (1); peter.iyere (1); ronclarke (1); suvi (1)
