Previous in Forum: Circles in Principal Circle   Next in Forum: Big Gun
17 comments
The Physics of Guitar Tuning
02/22/2013 4:00 PM
I was looking at a robotic Gibson Les Paul. There are servos in the machine heads and piezos in the bridge. A central controller reads the frequency of the string and tunes it to a user chosen tuning; I.E. std EADGBE, Drop D, Ab, modal DADGAD, Open G etc.
The salesman I was talking to about the guitar said it was a compromise because you cant change intonation; reset the bridge saddles, everytime you retune to a different setting.
That got me thinking, isn't the idea behind intonation just finely adjusting the overall length of the string, so it is matched to the fretboard? Won't the 12th fret always be half the length of the string, no matter what the note?
If the guitar is intonated in standard tuning, is it out when the tuning is changed?
MikeMack747
Re: The physics of guitar tuning
02/22/2013 4:34 PM
...as the string tensions change with differing tunings, so too do their "open vs. closed" lengths, ie: intonation lengths.
02/22/2013 5:21 PM
You'd do that at the bridge, in any case, right?
The machines still have manual knobs, too, because we all know that 99.9% of the people who pick one up will still fiddle with the tuning, no matter what.
Does this mean my Conn Strobe tuner is obsolete?
Good Answers: 918
Re: The Physics of Guitar Tuning
02/22/2013 9:39 PM
Once the intonation is set, it should be consistent regardless of tuning. In theory...
However, there is a catch!
When you change tuning what happens? The tension on the neck changes and so does the string length! This alters the intonation slightly relative to the frets as the neck changes position.
There are other factors such as which fret you are playing. Frets closer to the nut require more pressure than those further away, so it impacts the tension on the string.
In short, the auto tune is a bit of a compromise as would manual tuning. When you tune to an alternate tuning you so so without fussing with the intonation anyway, otherwise you would spend the rest of your life tuning rather than playing. Don't believe me? Well how about the G and B strings. Ever wonder why they never seem to be in tune? Yes, tune them for one chord by ear and they sound perfect. Play another chord and the new chord sounds wrong. Retune to that chord and the first chord is now out of tune.
Setting the intonation is not a trivial thing to do, much like tuning a piano sounds like it is simple, but it is not by a long shot! The neck tension, the bridge height, nut height, and how the instrument is played all impact intonation, so it is not going to be possible for a machine to automagically set intonation when detuning a string for an alternate tuning. This is why no one makes a system to do this.
Setting the intonation is best left to an expert who understands the subtitles of the process. The expert will set the intonation as a best compromise for the job at hand and the guitar itself.
Once set, changing to alternate tunings will have the least impact it can for the guitar and selected tuning.
02/22/2013 10:58 PM
When did they start putting subtitles on the tuning process? Was it in some other language?
I presume you mean subtleties...
Good Answers: 918
02/23/2013 7:54 AM
Good catch. I am going to use you as my spell checker. :)
Good Answers: 70
02/25/2013 5:58 PM
GA. I think the one aspect either I missed or you didn't explicitly mention is that tuning a string up increases the tension along the string (that's how tuning works), but the increased tension also makes it harder to deflect the string sideways as when you press the string down on a fret, even if the neck doesn't bow (due to the tension bolt that reinforces the neck). Your fingers can feel this. The extra force is stretching the string a bit more and this results in a slightly higher pitch. You are also right in your next post about tuning the higher strings a bit flat so that you hear a beat frequency. This is the basis of the 'tempered' vs 'natural' scale. Not only are the higher strings a bit flat, but the notes are also a bit flat as you go up the neck. If you only play the guitar by itself the difference is usually not much of an issue, but if you play with keyboards and spend much time up the neck it sucks noticeably.
Good Answers: 918
02/25/2013 6:34 PM
I agree.
02/23/2013 4:31 AM
Great post AH.
Another classic case where the simple mathematical/physical model and a shed load of software still isn't as good as a human (with a decent ear) who's had some practice.
I may be mistaken but I vaguely recall hearing that all this stuff about tuning following exact mathematic intervals isn't exactly true anyway?
(BTW I'm not into music, but the rest of the family is)
Good Answers: 918
02/23/2013 8:00 AM
I think you are right about not tuning exactly on. At least on my 12-string guitars having a small or minimal beat frequency between strings actually makes the guitar sound fuller rather than sterile.
I am thinking that the same thing applies to pianos. Tuning is more of an art than science.
02/23/2013 8:45 PM
I always assumed that the frets were spaced at ratios of 1 over 12th root of 2 (chromatic tuning) to give a compromise for whatever key you're playing in. I could be wrong on that. Maybe it depends on the guitar.
02/23/2013 9:03 PM
02/24/2013 7:46 AM
Thanks for the link. And I should have said tempered scale.
02/23/2013 10:18 AM
The frame of a piano on which the strings are mounted is made of cast iron and is designed [by engineers :)]to have nominally no flex at all since this is what will make the piano stay in perfect tune with perfect harmonics even tho the string tension is very high.
My '68 Les Paul standard which weighs 12#11oz. has adjustments on the bridge to allow for ultra-fine tuning set-up but I know of no one who resets them for different tunings, they usually have a roadie just hand them a different guitar, lol.
The action is the same height along the entire fretboard, roughly 2mm, and the ultra-light weight strings collectively have not enough tension it seems to my tin ear to affect the straightness of the steel reinforced neck no matter how far you bend.
You can do a vibrato by pushing on the head and base at the same time while bracing the body against your belly so there is flex in the neck but you have to force it.
You can pretty much play the thing with your left hand by 'hammering on' and using the volume and tone controls. It almost plays itself, lol.
I've never had it set up professionally because it would be wasted on my tin ear (trumpet and euphonium player consequently) so I use harmonics to tune it or an app on my Droid. Frets are mandatory and I can't play slide which drives me crazy. Tinnitis doesn't help either.
I like the Gibson necks because my digits are so short (hold the comments) so my collection now includes all Gibson Cherry Sunburst made between 1968-1972 and consists of a J-45, Custom Les Paul, A-4 Mandolin, a 3/4 size 12 string, and my first electric, an ES-125.
Staggers my imagination what they are worth now since I got them all for between $450 and $500 each over the past 40 years.
(My Yamaha 12 string has unbelievable good tone so it stays out in easy reach tho.)
02/23/2013 10:28 AM
02/23/2013 3:01 PM
This may be OTS, but your topic reminded me of something I read about a while back, a bridge that automatically keep a guitar from getting out of tune as a set of new strings stretches. It works by keeping a constant tension on the strings. http://www.popsci.com/diy/article/2010-05/invention-awards-plug-and-rock-out
02/23/2013 7:40 PM
Interesting but I doubt if I could ever bring myself to cut that big a hole in the back of an all original 1972 Les Paul...
02/24/2013 10:45 PM
Also, there is a point in a musician's learning curve when the ear overtakes the instrument whether it is fretted or not. (In some circles frets are considered a handicap.) People like these two seemingly have gone beyond the ability of commoners like myself and most others into a world innate ability far beyond the comprehension of most everyone.
http://www.youtube.com/watch?v=2gO7FI_ogvA
Register to Reply 17 comments
129CBRider (4); 70AARCuda (1); Anonymous Hero (4); dkwarner (1); johnfotl (1); lyn (2); Rixter (3); user-deleted-1105 (1)
