Previous in Forum: Electrolytic capacitor   Next in Forum: Solar Powered Go-Kart
Pin & Sleeve plugs modifications
05/27/2007 11:41 PM
Hello everyone. I'm having a lot of trouble at work with the 440 volts "Pin & Sleeve" plugs we're using. They're weatherproof with a locking nut. Sometimes the male won't fit deep enough in the female for them to lock properly, creating a hazardous situation. The question is: Are there any alternatives that you recommend to try out instead of the locking nut?
Pathfinder Tags: 440 V pin & sleeve
Re: Pin & Sleeve plugs modifications
05/28/2007 8:28 AM
Use the 600V rated CSA certified ones for hazardous areas these ones never let go.
crouse, or appleton. also brad harrison makes some too.
By the way these are used in oil refining they are not Cheap. but they never give the problem you are talking about
05/29/2007 6:17 PM
Any of the plug and socket range that are manufactured to Cee17/BS4343/IEC309 standards should not cause any problems. The manufactureres I have used are Mennekes / Crouse Hinds / ABL Sursom Never had a problem with locking rings or difficult fitting with any of them. Hope this helps
Peter
"Multa ferunt anni venientes commoda secum, Multa recedente adimiunt". (The years as they come bring many agreeable things with them; As they go they take many away).
05/29/2007 7:55 PM
what brand of plugs/receptacles are you using? Are they matching sets? We do a lot of work in power plants and we end up with a lot of the plugs and every once in a while we get some that wont quite match up.... you can buy parts for almost all of mfr's of plugs /connectors , and if you are having trouble w/them stop using them immediately!!!! the parts are cheap enough and easy enough to get not owrth energizing someone!!!!
05/29/2007 11:32 PM
Thanks all for your help. We´re currently using Appleton. The p/n for the female is ADR6044, and the male is ACP6044BC. They're are matching sets. The main problem is with the pins, which are damaged quite often for bad connections, because the worker that is plugging it in can't connect it properly. Does anyone have a part number for the pins alone?
Register to Reply 4 comments
Anonymous Poster (1); coconutpete (1); evelioj (1); yobski (1)
You might be interested in: Power Plugs, Shaft-hub Locking Devices, Nut Runners
