Previous in Forum: 3d iges models   Next in Forum: Angular to linear velocity
material for hanger bkt.
05/28/2007 1:49 AM
Dear friends,
we have some problems in our suspension system.
the hanger bkt. plate where the leaf spring comes in contact getting wear out very soon as a result of rubbing between the plate & the plate(where the load is coming).
do i need to change the plate material(anything harder than the leaf spring material)?
plz. help me to find out a soln.
Re: material for hanger bkt.
05/28/2007 11:53 PM
"hanger bkt. plate where the leaf spring comes in contact getting wear out very soon as a result of rubbing between the plate & the plate(where the load is coming)."
Can you be more specific as to the end application -- are you working with a support similar to a vehicle suspension?
It would appear as though your issue is not so much the hardness of the bearing plate against the leaf spring but rather an issue of eliminating the amount of movement between the two surfaces involved.
John
Engineering Fields - Mechanical Engineering - I am here to help!!
05/28/2007 11:57 PM
I don't quite get your problem. Pls elaborate.
05/29/2007 12:18 AM
You might consider a work hardening steel with a significant manganese content for the plate. Not easy to find in wrought material but readily cast.
Good Answers: 266
05/29/2007 12:08 PM
There is anti wear plate weld it where spring makes contact. I'd all check the shocks to make sure there ok or meet the application.
Anonymous Poster (1); Gnome1 (1); ozzb (1); pc (1)
You might be interested in: Hanger Bearings, Leaf Chain, Leaf Wetness Sensors
