Previous in Forum: How to Confirm the Existence of Greases and Oil Seal Inside Motor w/o Dismantles   Next in Forum: Motor Generator Frequency Converters Manufacturers
Insulation Piercing Connector
03/05/2013 11:48 PM
TO supply electricity (230V AC) to terrace houses, the practice here is to run four (3p + n) insulated cables along the front of the terrace of houses. Cables are PVC insulated 35sq mm aluminium conductor. To connect each house, a tapping is made from one phase and neutral for single phase connection. The tapping cable is PVC insulated, either 35sq mm or 25 sq mm alumimium.
For the tapping connection insulation piercing connectors (IPC) are used of the same type used on Aerial bundled conductors (ABC).
We suffer a too high incidence of over heating and failure of these IPCs leading to loss of supply to the house. The loads are significantly lower (perhaps 15-25amps) than the rating of the IPCs (60-100A). We are aware that correct matching of the IPC to the conductors and correct torque when fixing the IPC are necessary to get good service.
Is anyone aware of a good alternative to using IPCs that is both easy to use, relatively low cost and gives good performance?
Re: insulation piercing connector
03/06/2013 12:06 AM
Ask the cable manufacturers to recommend a suitable IPC.
pnaban
03/06/2013 10:24 AM
Get a well experienced technician to check the connection
pnaban
03/06/2013 1:16 AM
Check the connection. May be loose contact is causing the problem.
Good Answers: 445
Re: Insulation Piercing Connector
03/06/2013 9:36 AM
Something doesn't sound right. If you're working for a utility/contractor you should be able to present your problem to the IPC supplier who will work with you to understand the nature of your problem. If not then start searching for an alternate vendor who can supply something like this.
On the other hand if you're using a tap rated for ABC but not supporting it properly, then anything that allows either of the conductors to move (wind, street vibration, people, etc.) will accelerate the creeping of the al and ultimately cause a poor connection leading to heat cycling and ultimate failure.
03/06/2013 7:42 PM
Thanks for the info on Michaud.
The IPCs are properly tightened on installation (using shear heads ). The connections are not subject to wind or other vibration
However my main question asks if there is a suitable alternative to using IPCs for these tap connections.
03/07/2013 8:16 AM
The most reliable method of joining two conductors together is called a CAD Weld.It melts the 2 conductors together to form one solid piece.No vibration or temperature issues with this connection.
Then there is the old but reliable split-bolt or parallel clamp connection.If properly installed can give years of trouble free service.
Reliability is paramount in your case, and repairs cost much more than doing it properly the first time.
Insofar as insulation-piercing connectors go, I would consult with the current manufacturers engineering dept to determine why their connectors are failing.I am sure they are as equally interested in learning the failure mode of the connectors as you are.
Good Luck!
03/07/2013 8:33 AM
I tried to get this in under the edit time limit, but failed to do so.
Here is a link to the man that wrote the specs on IPC connectors, with instructional video.
http://www.youtube.com/watch?v=n75qR-eBx0c
Register to Reply 7 comments
arifkunnath (1); eugene344 (1); HiTekRedNek (2); pnaban (2); RAMConsult (1)
