Previous in Forum: Biolux NG Microscope Driver   Next in Forum: Linux and Unix
Basic Shell / Bash Programming Linux / Unix
03/15/2013 4:31 PM
echo "what month..." read month echo "what year..." read yearif test " $month = [1-12] "
then cal "$month" "$year"
echo "you are now being redirected to the menu"
bash program.sh else echo " you entered a wrong number for month" exit 0
fi
So Im trying to write a command that shows a specific month and year you typed for the selections you enter but I can't figured to prevent the error cal month 13 is not a month...
Here's what is supposed to do....You typed a number for a month you are looking for, example january 1,february 2you typed a number for the year you are looking for ,example year 2012,2013 but I want to prevent that if the user types for instance month 13which is non existance to return him to the main menu which will run the script again..
Re: Basic Shell / Bash Programming Linux / Unix
03/16/2013 4:21 AM
Read about data validation.
You require a line to redirect back to the start if the entered value is outwith the selection available. Also, let the user know what format to enter, so they do not attempt text.
Madness is all in the mind
03/16/2013 6:52 AM
[?maybe]
if test " $month = [1-12] " <- (* http://www.linuxquestions.org/questions/programming-9/%5Bbash%5D-if-clause-718161/)
bash program.sh
fi
(from http://www.bing.com/search?q=linux+bash+batch+if+clause)
http://linuxconfig.org/Bash_scripting_Tutorial#9-bash-if--else--fi-statements
http://linuxconfig.org/Bash_scripting_Tutorial#10-bash-comparisons
if [ $NUM1 -eq $NUM2 ];
ci139
03/16/2013 1:24 PM
I think "yearif" is run together. The if is the start of an if loop that ends in "fi". Put a return after "year"
Register to Reply 3 comments
ci139 (1); GM1964 (1); Rixter (1)
