Previous in Forum: Single End Bonding with Surge Arrester for 6.6 kV Cables   Next in Forum: Homebuilt Wind Turbine
Data Monitoring
04/02/2013 9:35 AM
hi, good day everyone..we are currently planning on one having a data monitoring specifically feeder by feeder data's to facilitate our load curtailment scheme... the distance from the our office to some feeders would cover about a few km to a hundred..i would be grateful to hear your feedbacks and suggestion regarding the matter..
take care of your seconds and the minute will take care of itself..
Pathfinder Tags: data monitoring
Re: Data Monitoring
04/02/2013 10:40 AM
First, you need to define the requirements of the system.
You can do this by listing what parameters you want to track and what you want the data to do.
Not enough information for ANY action.
Good Answers: 44
Re: Data Monitoring
04/02/2013 11:01 AM
1) Supply power to your monitoring center from the source you wish to monitor
2) If the lights stay on, you are good
2) If power dips, you are overloaded
3) If power goes out, you have a fault
4) done
Re: Data Monitoring
04/02/2013 2:15 PM
Look into your existing system data monitoring and communications network see if you can use that.
Look to add remote monitoring to existing feeder switchgear or data monitoring devices if it is not already there.
Add additional sensors if needed.
Try and tap into your existing SCADA network (if any). Do you have protection relays or similar? Are these not connected back to a control room which is network-connected to other sites or back to your office?
If you cannot, add wireless, fibre, Ethernet, etc and try to connect to local communication links rather than trying to build a completely new communications network.
Register to Reply 3 comments
cuba_pete (1); jack of all trades (1); lyn (1)
