I don't know if an air phase diagram will help answer my questions. This one is from Wolfram.
A thermal compressor or positive pressure jet pump is driven by high pressure air, say 1000 psi for example. In the throat, the temperature is low enough to condense the drive air. The increased density of the liquified air is like the condensed drive steam in a boiler injector. The result is that atmosphere is pumped into a 200 psi tank along with any unused energy in the drive jet.
To keep the jet drive from having to overcome the inertia of the suction air, the atmosphere can be mechanically pumped into the suction port at 0+ psig.
Heat can be added to the drive air, but I think pressure is better.
As I see it, in order to work, the drive air has to liquefy. The analogy is the boiler injector. Steam from the boiler condenses in the device when it contacts the suction water, and the density of the water as well as the heat and latent heat energy it contains can put cold water into a pressurized boiler with no moving parts. While the efficiency of injection or entrainment is very low, the efficiency of the system is 100% minus small losses due to leakage or heat dissipation through piping. Energy not used to entrain goes back into the reservoir.
In the air version, the compressor providing drive air is a booster inside the pressurized environment so its work input converts to heat and stays in the system.
Steam is not made by the sun but atmospheric heat is. So this is a concept for pumping heat energy uphill so that the atmosphere is pressurized, thus able to expand so its already-existing internal energy can be used.
Skeptics pronounced the boiler injector impossible long after it was available at Boilers-R-Us. But the guy who invented it flew 50 years before the Wright Brothers and his name is inscribed on the Eiffel Tower.
Thanks.
