Previous in Forum: Surge Arrestor Rating   Next in Forum: Electrical Draw Out
What is the Maximum No Load Current % in Transformers?
05/06/2013 5:13 AM
What do the standards say is the maximum no load current % in transformers ???
"Do not follow where the path may lead. Go instead where there is no path and leave a trail."
Good Answers: 73
Re: What is the Maximum No Load Current % in Transformers?
05/06/2013 12:30 PM
Try reading about this here
I'm not sure there are standards for this. I believe that you will find that a large part of the variation has more to do with the construction of the magnetic core. One of the reasons that magnetic cores are made from layers of metal is to reduce the amount of eddy currents circulating within it. In order to get a standard, all cores would have to be very nearly the same. That is a little bit like saying that all cars must be the same.
05/07/2013 4:06 AM
Thanx a lot ..
Register to Reply 2 comments
