Previous in Forum: Unknown Tool   Next in Forum: Field Professional Assistance
Design of a High Density DC Brushless Motor
05/07/2013 11:11 AM
Currently, we have tested several brushless motors and now need to work on the exact specifications for a custom design. We have extrapolated requirements from smaller test motors (the speed controllers of these motors log critical data so we have a lot of information available) and are about to test our latest.
Using some of the advanced technology from the RC community we have a motor with the following specs:
10 kw continuous power with 20 kw surge
Weight 6.0 lbs Height 4.5" Length 3.5"
10,000 RPM max geared down to 4:1
Kv 117
Max volts 85
We run this motor with 4 4s LiPo in series (16 total)
In early tests we can see we are drawing > 300 Amps but measuring torque is proving difficult. (> 175 NM)
Question 1: It works for our application but how can we optimize efficiency? So far it has been trial and error (and error is getting expensive). Ideally we would like this motor to be in a pancake configuration
Question 2: How can we find an engineer to add to our team? We are a two person startup with some very promising new technology (patents applications are in the PTO).
Thanks in advance,
Vitanaut (CR4 first timer)
Pathfinder Tags: brushless motor DC
Re: Design of a high density DC Brushless Motor
05/07/2013 11:16 AM
I doubt anybody here will want to design a motor for you.
So, start here↓ and be prepared to pay someone for their time, or promise them that they can sell you a million of them, when designed and built.
Custom Motors and Custom DC Motors by OEM - Ohio Electric Motors‎
05/07/2013 11:24 AM
Lyn,
Thank you. I don't mind paying and have already talked to several (of the very few remaining) US manufacturers.
I would rather work with (and pay) an engineer here first so that I can go to the OEMs with more accurate requirements.
I hope notion this isn't offensive to the community...
05/07/2013 12:06 PM
Good for you. There may be someone here who is willing to help you, off line.
Good luck with the project!
05/07/2013 12:17 PM
Wow.
"10 kw continuous power with 20 kw surge
Weight 6.0 lbs Height 4.5" Length 3.5" "
Thats a power density of about 2.2 lbs per HP.
Any chance you could post a torque/rpm curve?
Yes; I know a Chinese Engineer who has extensive experience in motor control who might jump at the chance to bring him and his daughter to the US for a while. I was helping him work on a resume. His English writing skills are fairly good; he would spin up on conversational english quickly.
Let me know if you are interested.
I will send you a message.
Register to Reply 4 comments
Gavilan (1); lyn (2); Vitanaut (1)
