Previous in Forum: Quartz Glass Tubes   Next in Forum: Chemical Injection system
Positive photoresist studies
06/01/2007 2:44 AM
Hello everybody,
I'm looking for someone who is working with positive positive photoresist (PAC) and UV laser source.
Indeed, we bought a Diode laser which match with the required fluence (mJ/cm²) but process is not conclusive. Does anyone work with a similar illumination source?
Where can I find studies on the resolving of the Dill's equation or the influence of the exposure time on the required fluence ?
Thanks for your help,
Re: Positive photoresist studies
06/02/2007 4:14 AM
please tell me in detail what u wan to do im a photolithiography xprt
06/02/2007 9:54 AM
I agree, somewhat, with our 'Guest'. It would require further details. However, all the information you require would be available from the manufacturer of the resist. If their spec.s are for a different lamda, then tell them what frequency you are using. They will help! Ashman
If life is like a box of chocolates, why do I get the coffee one? That sucks!
06/04/2007 3:19 AM
Ok, so I will explain the goal of the experiment.
I need to illuminate a positive photoresist over a stainless steel substrate in order to get some holes (after development) into the photoresist film.
When I talked with photoresists contructor, they all give me 1 parameter : the energy density in mJ/cm². Unfortunately, when I put this value with my Diode laser, the holes aren't well defined. I noticed that the energy density was given for long exposure time (approx. 10ms).
After this step, I looked for litterature on this topic, and I found the Dill's equation and parameter, and I saw that absorption is depending of exposure time (because of the bleaching aspect of a resist).
So the questions, now, are :
--> As absorption changes with the exposure time, is the energy density required for the resist changes with exposure time? (I would naturally answer yes)
--> Could we find some graphs showing the Energy density required vs Exposure time?
--> Is it possible to resolve quickly the Dill's equation?
All these questions have one goal : find a photoresist film suitable with my laser source.
Thanks,
06/04/2007 3:55 PM
The resist manufacturer can tell you if the frequency(wavelength) of your laser is appropriate for the resist you have. All the resists I have ever worked with have required a set frequncy range for best exposure results. You did not mention the wavelengths you are working at. There are many resist manufacturers. I am sure one of them them has a resist designed for the wavelength you have.
06/05/2007 3:18 AM
Yes it's right I forgot the wavelength : 375nm.
As I explained before, I would know if there's only one optical parameter : the density energy (by wavelength).
We already did some experiments and there weren't conclusive. But yesterday, we get results of other illuminations and it seems to be OK. Indeed, for my wavelength I nedd apporimately 100mJ/cm² and we did some tests changing Light power & exposure time in order to get different couples of solutions and the results were in accord with the required energy density.
Maybe, the first series was done with bad conditions (photoresist, thickness, development...)
So for me everything is OK.
Thank you for your help,
Anonymous Poster (1); Arag24 (2); Ashman! (1); silvCrow (1)
