Previous in Forum: What Produces Second Harmonic Current?   Next in Forum: Drop Bottom Furnace
ETAP 6.0.0 Wind Turbine Generator
06/14/2013 12:05 AM
hello...
I want to ask something about the wind turbine simulation on etap 6.0.0, I do not quite understand about the simulated wind turbine, Can you give an example of the circuit and simulation tools should I use so that the simulation can work?
Pathfinder Tags: etap wind turbine genarator
Good Answers: 445
Re: ETAP 6.0.0 Wind Turbine Generator
06/14/2013 12:29 PM
Perhaps, but first tell us what you've tried that didn't work, and what you can't find or understand in the ETAP help files.
06/14/2013 9:00 PM
in this system I use "load flow analysis", but after the run etap say
"Error 2000: Number of energized buses is less than two" and
"Error 2002: The system has no branches energized"
I do not know where the location of the disorder, can you help me to solve this problem?... I also do not quite understand, if the system that I've made have been right or still wrong?
Register to Reply 2 comments
