Previous in Forum: 2 pin SAE connector   Next in Forum: Variable resistor to change 12 volts from 1 to 12
a problem in Digital Logic
06/02/2007 12:25 AM
Hi
Problem 10-4 in Digital Design by Morris Mano asks about the NAND gate below.
assuming beta=100,so Ic=2.4 mA when All A,B & C are high so the Transistor is saturated.
You know one of the week points of DTL gate is its number of outputs ( upto 8 in the above circuit) and this is what i can't understand why!
I mean I can't understand why there cannot be over 8 outputs for this gate.
Problem 10-4 of Digital design discusses this issue. I need help understand the problem and so the fact that there can't be more than 8 outputs. here it is"
10-4
Connect the output "Y" to N input of similar gates. ( the transistor is saturated )
a) what is the current of the 2K resistor? ( solved, 2.4 mA)
b) What is current we get from each input? (the answer is 0.82 mA but i don't know how and why?)
After I understand part b, we can go to the rest of the problem:
c) calculate the collector current based on N. ( answer is 2.4+0.82N)
d) what is the maximum of N if we want the trasistor to be still saturated
Re: a problem in Digital Logic
06/03/2007 12:58 AM
Because Vil and Vih will be above and below the threshold for the inputs of the next stage of logic. You will have no noise margin on the inputs. Any ringing on the power supply or transmission line will cause spikes on the outputs of the next stage of logic because their inputs are too close to the threshold limit. Vsat/Vil for this output should not sink so many input loads that is DC value is above .6 volts. Also when in the opposite state the Vih should be above 3.8 volts. If too many loads are hooked to the output the drop across the 2k pullup resistor will be high enough to keep the output DC steady state below 3.8V. You can probably hook more then 8 but you will lose your noise margin and spikes in a system are very compromising if this signal output is used to trigger a D or JK flip-flop somewhere.
06/04/2007 1:07 AM
Lets say stage-1 is giving the output and stage-2 is getting that output as inputs.
Now when stage-1's output transistor is saturated its Vce is assumed as 0.3V
And, Stage-2 has diodes and at the input and have a pullup resistor of 5K connected to 5V. This setup can deliver a current which can be calculated as...
5V-(stage-2 diode drop + Stage-1 transistor's Vce) divided by 5K
= 5-(0.6+0.3)=5-0.9= 4.1V/5K= 0.82mA
Please Let me know how can you go through the rest of the solution...
I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. :Albert Einstein
06/06/2007 10:29 PM
How U can connect a capacitor in I/P of a logic Cct. These are DC coupled ones not a Schmitt Trigger
06/30/2007 9:34 PM
Fan-out and Storage in TTLs is a problem, but the Gates are always operated at saturation.
Register to Reply 4 comments
Anonymous Poster (1); gayatrikumar_1 (1); Haajee (2)
You might be interested in: Gate Valves, Gate Drive Transformers, Gate Drivers
