Previous in Forum: Boiling Point at altitude?   Next in Forum: Wear of aluminum alloys
dielectric
06/02/2007 2:23 AM
Hello Gents, can any body make it clear what is di electric joint. Thank you.
Re: dielectric
06/02/2007 7:57 AM
A dielectric joint in mechanical system, is a joint between two dissimilar materials usually in process piping, where the dissimilar materials will be subjected to an electrolytic exchange causing corrosion of to the two materials; this is usually accelerated by the substance carried within the piping. Dielectric joints come in various forms from rubber or plastic separators to ceramic coated joints.
Good Answers: 27
Re: dielectric
06/05/2007 2:08 PM
And a real good example are the dielectric unions that are commonly used to connect copper water lines to the steel tank of a hot water heater.
