Previous in Forum: Omni Flow Computer Malfunction   Next in Forum: Cleaning Up a Computer
C++ Displaying a Text File...("Echo" a Text File)
07/18/2013 11:38 PM
So I'm really stuck trying to figured this bug on the program that is preventing me from displaying the text of my program..
#include <iostream>
#include <iomanip>
#include <fstream>
#include <sstream>
#include <string>
#include <stdio.h>
using namespace std;
int main ()
ifstream infile;
ofstream offile;
char text[1024];
cout <<"Please enter the name of the file: \n";
cin >> text;
infile.open(text);
string scores; // this lines...
getline(infile, scores, '\0'); // is what I'm using...
cout << scores << endl; // to display the file...
// Is there any way cleaner or simple method i can used to display the file ?
//All the method in the internet are difficult to understand or keep track due to
// the file is open in loop..
//I want a program that you type the name of the file and displays the file
// the file will contain the following...
// jack 23
//smith 27
//also I need to obtain data from the file
//now I'm using the following code to obtain that information from the file...
string name1;
int name2;
string name3;
int name4;
infile >> name1;
infile >> name2;
infile >> name3;
infile >> name4;
cout << "these two individual with their age add are" << name2 + name4 <<endl;
// 23 + 27
//the result I get is a bunch of numbers...
return 0;
Re: C++ displaying a text file...("echo" a text file)
07/19/2013 1:53 AM
is "cout" correct or do you need a "count" there?
Looks dodgy!
Otherswise: No Idea!
Good Answers: 38
07/21/2013 9:01 PM
07/22/2013 8:43 AM
Cheers! Long since I had to look at these things and never done C-plus. Good reference page. Why did you put this Off Topic?
Good Answers: 38
07/22/2013 8:34 PM
Bcuz it was your question and not the the thread owner's question.
Good Answers: 38
07/19/2013 3:02 AM
This could be better asked on a C++ forum,
What is the location of your file?
I see no code that catches errors
where do you want to display the file? on the console?
Search the web there are many C(++,#)
Download Visual C from Microsoft it is vary useful (or eclipse)
Re: C++ Displaying a Text File...("Echo" a Text File)
07/20/2013 10:38 AM
Several problems here. First, the line
string scores;
allocates space for the object, but does not initialise it. You need to rewrite as
string scores = new string;
Second, your code reads the entire text file into a single string object. This is legal, but it does not help when you want to process individual lines. I prefer to read individual lines into an array of strings, or even a linked list of strings, identified by an index, but you can do the same from your big string by using an iterator to pick up individual characters:
string singleLine = ""; // another way of initialising
string::iterator iter = scores.begin(); // start of string
while (iter != scores.end()) // still characters to be extracted
while (iter != '\n') // end of line marker
singleLine += *iter++; //add single character and move iterator
// process a string "Jim 37" here
}// move on to next line
Register to Reply 6 comments
Epke (3); IdeaSmith (2); phph001 (1)
