Previous in Forum: No-Metallic Materials   Next in Forum: Does the Height of Installation of a Window A/C Affect the Cooling?
Grinding Silver Wire Without Putting On Coolant
08/01/2013 6:55 AM
Hello....need some info
If I were to grind a silver wire (Ag) with purity of 99% with any coolant, would I get burn mark on the silver wire?
Many thanks in advance.....
Re: Grinding silver wire without putting on coolant
08/01/2013 7:34 AM
heat it up to over 1700 F before you begin to grind
Re: Grinding Silver Wire Without Putting On Coolant
08/01/2013 9:25 AM
Grinding?
This indicates loss of the metal, recovery of which will be complicated by inclusion with grinding medium.
Can you not deform (flatten and elongate) the wire instead?
08/01/2013 9:50 AM
Your thread title "Without Putting On Coolant".
Your thread question, "with any coolant".
Depends on the feed rate and the heat generated by that feed rate.
So, yes, you can grind without coolant.
08/01/2013 10:46 AM
Another consideration. Cooling is not the only function of the solution. It is also a cutting fluid that aids in the release of ground material from the grinding media.
Silver is pretty soft and you might get a wad of silver thrown at you if the wheel loads up.
You have to actively participate in the manifestations of your own joys and good fortunes - they are not ready made for the taking, they are available for the making.
Doorman (1); Fredski (1); lyn (1); Mike W (1)
