Previous in Forum: Thyristor 81RK100 Question   Next in Forum: Tranformer 1500KVA 11KV/415V
Current and Voltage Divider
08/05/2013 12:25 AM
Hello my friends. I got another silly question to make. Can I use voltage divider or current divider when I have a circuit with dependent sources?.
Re: current and voltage divider
08/05/2013 3:13 AM
The question is too vague and presumably you mean independant?
In electronics things are rarely completely independant. They are normally referenced to ground, some common voltage or eachother.
If two voltage sources are completely separate then they can be connected by joining just two termials with impunity.
E.G. A 9v battery and 6v battery could be joined with the + of the 6v joined to the - of the 9v That join could be tied to a notional 0v rail and you'd then have a -6 0 +9 supply.
Dunno if that helps, because the Q was so vague. Please try and write more concise questions as it will improve both your understanging and the quality of the answers.
08/05/2013 3:15 AM
Of course you can, Guvnor. There's no law against it.
Good moaning!
Good Answers: 42
Re: Current and Voltage Divider
08/07/2013 7:12 AM
Julius
Register to Reply 3 comments
7anoter4 (1); Crabtree (1); user-deleted-1105 (1)
