Previous in Forum: Duration of Hours a Submercible Pump Can Run Without Stop   Next in Forum: Level of Accuracy for Pressure Gauges
Radiography After PWHT
08/25/2013 12:45 PM
Dear all,
Kindly help me on following issue
i want to know reference of Requirement of radiography after PWHT
CONSTRUCTION CODE- ASME SEC VIII DIV.I
MOC- P NO 4 & shell min thk - 18 mm
Kindly reply fast
thanks in advance
vishnu
Re: RADIOGRAPHY AFTER PWHT
08/25/2013 12:51 PM
Not enough information.
Hope that was fast enough.
Re: Radiography After PWHT
08/26/2013 3:49 AM
Dear lyn
Thanks for reply
CONSTRUCTION CODE - ASME SEC VIII DIV 1ED 2010
MAWP- 3.822 MPa @ 270 ° C
MDMT-(-8° C @3.822 MPa
PWHT - SOAKING TEMP 670° C FOR 2 HR SOAKING TIME
RADIOGRAPHY- FULL (RT-1)
JOINT EFF- 1
Pressure vessel MOC - SA 387 GR 11 CL2
P NO - 4 GR NO 1
THK OF SHELL & DISHED HEAD - 18 MM
AS PER TABLE UCS 57 - FULL RADIOGRAPHY REQUIRED FOR BUTT WELDED JOINTS
SO HOW WE CAN CHECKED FOR SAME DETAILS RADIOGRAPHY AFTER PWHT REQUIRED OR NOT ?
08/26/2013 8:47 PM
By my memory (you need to verify), ASME VIII is silent on whether radiography is carried out before or after PWHT. Obviously it is usually done beforehand to ensure non-compliant welds are not PWHT and then found to need repair. However, due to the possibility of previously compliant defects, eg inclusions, moving or growing during PWHT, some purchasers specify RT both before and after PWHT. I know i have when working in that sort of role.
If this was agreed/required at time of purchase, then it should be specifiied in the approved ITP (Inspection & Test Plan), assuming it is a purchaser requirement over and above code. If not, sounds like a scope change.
As an aside, you state thickness is 18mm, i recall ASME VIII requires PWHT only from 19mm (3/4") & thicker? Thus sounding even more like purchaser requirements - good practice, but in excess of code?
08/27/2013 2:36 AM
Thanks dclarihew for your reply
1. as per your comments there is no reference given in sec viii div 1 regarding RT after PWHT
2. can you give reference in code for PWHT requirements you mentioned 19mm & thicker for LAS material ?
anyone have some other information regarding RT after PWHT??
09/04/2013 7:46 AM
Radiography can be performed either before or after PWHT when following ASME Sec. VIII Div. 1 or 2. There hasn't been any sequence specified.
However, you may need to look into the specifications of the job you are performing. Moreover, ASME B31.3 asks for radiography after PWHT for certain materials prone to carcking /defects after going through post weld heat treatment.
Birken
Good Answers: 34
12/04/2013 5:16 PM
Hello, 19mm for CS. He has low alloy material P4. RT before PWHT is only for your health. RT before PWHT is non-mandatory. After is Mandatory. Both are a practice. Review ASME VIII edition 2010 UW/10, UW11 and UW40.
WP
Good Answers: 34
12/04/2013 5:22 PM
PWHT
1.- By Thickness
2.- By Material
3.- By Fluid
WP
Register to Reply 7 comments
birken (1); dclarihew (1); lyn (1); vishnus.2184 (2); Whitephone (2)
