Previous in Forum: Elevated Bearing temperature on Falk Gearbox   Next in Forum: Brinell Hardness of Steel
Brinell Hardness Test
09/07/2013 12:47 AM
why do the brinell hardness numbers obtained from the depth of indentation usually differ from those computed from the diameter of indentation?
Pathfinder Tags: brinell hardness
Re: brinell hardness test
09/07/2013 1:03 AM
  • You are performing the test improperly.
    Brinell Hardness Test Method
  • The Brinell hardness number is a function of the test force divided by the curved surface area of the indent. The indentation is considered to be spherical with a radius equal to half the diameter of the ball. The average of the two diagonals is used in the following formula to calculate the Brinell hardness.
