Previous in Forum: Charge-as-You-Drive   Next in Forum: Repairing Rubber
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member
Non Standard Notation?
09/14/2013 12:54 AM
this is from http://www.eng-tips.com/faqs.cfm?fid=314 quote:
System generators do not generate negative sequence currents, but negative sequence can flow in their windings. For rotating machines X2 = 1/2(X"d + X"q). Except for calculating faults very near machine terminals, can assume X"d=X"q, so X2 = X"d.
does X2 mean X sub 2? does X" mean X^2 ? what are the definitions of q and d?
BSEE but always learning
Re: non standard notation ???
09/14/2013 11:07 AM
Click on the Join below and ask them.
Good Answers: 445
Re: Non Standard Notation?
09/14/2013 10:21 PM
This is a bunch of those Electric Power Engineers' trivia questions that if you have ask it means that you have not taken a basic electric machines course:
does X2 mean X sub 2? Yes, the sub 2 denotes Negative Sequence
does X" mean X^2 ? No, it means Subtransient reactance.
what are the definitions of q and d? direct and quadrature.
For more info Google on each of your questions. Class dismissed.
Register to Reply 2 comments
