Previous in Forum: Accepted ASTM or NACE Standard for Oil/Gas Pipeline Coatings   Next in Forum: 150 Years of London Underground, in Pictures
Ball Mill - for Cement/Powders
09/18/2013 11:51 AM
Does anyone know about ball mill designs for milling small product into a powder-like size? Specifically, would you use a sieve on the outlet, and would you have to slope the rotating drum downward toward that end? This application is for a drum around 3 or 4 feet in diameter. Thanks for any advice/help.
Pathfinder Tags: Ball Mill
Re: Ball Mill - for Cement/Powders
09/18/2013 1:09 PM
09/18/2013 3:33 PM
Typically you would not slope the ball mill to assist flow. The outlet end of ball mills (for grinding to powder) have a screen that lets the ground material out but not the grinding media. Just beyond the screen are lifters that lift and funnel the material to the outlet that goes thru the center of the trunnion. The lifters often are static spiral slides that raise the material as the mill rotates. The speed the material passes thru the mill is usually determined by feed rate, outlet screen percent opening and other attributes.
The feed going in a ball mill usually has a product distribution (like a histogram) and the product coming out has a product distribution (histogram). This means that how outlet product size is specified is very important. It could be as simple as saying "at least 95% of the output must be smaller than 200 micrometers" or as complicated as defining the whole size distribution.
Many mills with simple product specifications just pass the material thru it once. You control the maximum particle size by feed rate, media level etc. You might have a screener on the output to scalp off oversize. More sophisticated systems pass the oversize material thru the mill again. The oversize separation is done with equipment suitable to the product size. Oftentimes this would be screens or air classifiers and back to the feed end.
Everything I know about opera I learned from Bugs Bunny
Register to Reply 2 comments
