Previous in Forum: Acid in Gel form for Stainless Steel Cleaning   Next in Forum: Surface finishes of metal die-cast parts
8 comments
D2 Knife Blades
06/06/2007 9:04 AM
I have been told that D2 knife blades are the best and also expensive.
If this is true, please explain the facts.
Re: D2 Knife Blades
06/07/2007 5:11 PM
D2, hardened by heat treating is extremely durable. We use it for rollforming rolls and die components. It is so hard that a file cannot scratch it. It lasts when shearing and punching steel, under many thousand PSI, it should cut food with much aplomb, I have not heard of it used in knife making before.
Re: D2 Knife Blades
06/07/2007 5:26 PM
iIwould rather use M2 tool steel rather than D2.
M2 is tougher than D2 so it will not easily chipped (for cutting insert application).
kim
usa
Good Answers: 120
Re: D2 Knife Blades
06/07/2007 6:10 PM
Per Ardua Ad Astra
Re: D2 Knife Blades
06/07/2007 6:54 PM
D2 will rust and rather quickly. Living in the northwest and being around salt water regularly makes it not one of my favorites. I prefer ats-34 also called 154cm. I have not tried bg-42 yet but from seen literature it appears to be superior for knives. All of these cost more and are harder to work with than D2. there is also a non-stainless steel called M2 that might interest you. It has great edge retaining qualities.
Good Answers: 50
Re: D2 Knife Blades
06/08/2007 1:14 AM
Not to correct you, but are you sure you're not getting some of the properties of D2 and M2 confused? M2 has a little bit more toughness, but it's not stainless, so it's usually BT2 coated, and even then you need to watch it like carbon steel. On the other hand, D2 has a rather high chromium and vanadium content that render it rather stainless (sea water may be nastier than I thought).
Another point, Benchmade has discontinued using M2 in any of its folders, if not all together. They now prefer D2 and 154cm.
Re: D2 Knife Blades
06/07/2007 7:15 PM
Tool steels such as A2 D2 O1 have excellent IMPACT resistance but not so great ABRASION resistance. M2 is indeed a better choice. Plain old 4150 is great for knife blades, just doesn't have the same corrosion resistance.
Re: D2 Knife Blades
06/08/2007 12:28 PM
Theirs a new tool steel in town it called DC53 its better then D2 .It has a uniform fine grain structure has double toughness and dramatically improved fatigue strength. I found it at www.alro.com
Help me with the things i don`t know . I`ll try to help you with the things i do know and we`ll both get smarter
Re: D2 Knife Blades
01/16/2011 12:24 PM
Caldie toolsteel is better than D2 because it has properties that allow it to take more shock. The edge may not hold up quite a good as D2 but a little touch up now and then is better than a broken knife.
Anonymous Poster (3); aurizon (1); MADMACHINE (1); madscientist (1); silvCrow (1); vermin (1)
You might be interested in: Knife Blades, Saw Blades, Fan Blades and Propellers
