Previous in Forum: Charging Electric Car Batteries with “Portable” Battery Packs   Next in Forum: Ice Shelf too Big to Tug?
8 comments
Good Answers: 141
Can .PPS Files be Attached to Answers
11/15/2013 5:19 PM
Hi Folks,
Is it possible to insert a .pps slideshow in this medium?
Yes, No, this is how?
Thank You
Plenty of room here
Re: Can .PPS files be attached to answers
11/15/2013 5:39 PM
Good Answers: 141
11/15/2013 8:55 PM
Thank you. The difficulty is that I have no link, but received it as a ,pps file, attached ti email. I need to get it as a download from this folder.
Plenty of room here
11/15/2013 11:04 PM
Re: Can .PPS Files be Attached to Answers
11/16/2013 11:09 PM
Can you not just rename the file to .ppt, open it in Powerpoint, edit how you want then save it again as .pps?
I just tried it and it worked fine...unless I'm not understanding what you want to accomplish.
Good Answers: 141
11/16/2013 11:50 PM
As I understand it well, here in CR4 we can attach pictures and links. The pics are in .jpeg and the links can be found e.g. on the internet. Suppose you receive an attachment .pps with an email and you download it to your download folder, how can you get it from that folder to import the file (e.g. a slideshow) into an answer on a post here?
Plenty of room here
New Zealand - Member - Member Australia - Member - Member
Good Answers: 43
11/17/2013 4:06 PM
The short answer is No.
But if you were desperate, you could convert each page of the Powerpoint to an image and upload all the images.
Good Answers: 141
11/17/2013 7:32 PM
Thank You
Plenty of room here
Good Answers: 119
11/18/2013 6:25 AM
If you want to "share" files with CR4 users, you would first need to set up a file/document/picture storage place* on an internet server. Then upload your files to that server and place links to those files in your CR4 posts/responses.
* Search Google for "free internet file storage sharing"
I can't rate any of the easy online storage solutions because I chose the difficult path of setting up my own L.A.M.P. internet/web-page server (Linux, Apache, MySQL, Php) using an old PC. The home server method works IF you are a computer nerd and enjoy investing a significant amount of time and effort learning how to set up an internet file and web-page server.
Register to Reply 8 comments
AussieBob (1); dvmdsc (3); mjb1962853 (1); SolarEagle (2); TerraMan (1)
