Previous in Forum: In Search Of The Perfect Vehicle....   Next in Forum: MWt Versus MWe
Emil J Paidar Barberchair Repair - Anyone?
11/20/2013 4:10 PM
I am needing some instruction on repairing my 1939 Emil J Paidar Barberchair. It will not go up and down or swivel, it will, however recline. Has anyone come across this problem before and have a recommendation as to how to fix it?
Thank you.
Re: Emil J Paidar Barberchair Repair - Anyone?
11/20/2013 8:12 PM
First I would search this site....
http://cr4.globalspec.com/search/sitesearch?do=show&order=asc&sort=textmatchrank&srch=barber%20chair
Can you post pictures of the chair...that would help...
You can try these guys for info.....
http://www.barberchairexperts.com/
11/21/2013 12:43 AM
Is there any corrosion visible?
11/21/2013 1:29 AM
Best source is...
CR4 ADMIN - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
"Real Bass Players" do not use picks
Good Answers: 25
11/21/2013 6:24 AM
There are to-day questions on Barber Chairs, is it collector's item or professional problem?.
11/21/2013 9:55 AM
No known corrosion. This is a personal item - I will try the contact information above thank you so much for your help!
11/21/2013 6:11 PM
If you have enough oil, then it sounds like a valve failure or main plunger rebuild necessary....just guessing though...
Register to Reply 6 comments
beddy2337 (1); IdeaSmith (1); Jimh77 (1); SolarEagle (2); suresh sharma (1)
