Previous in Forum: Dilution Percentage   Next in Forum: Equivalent Material for Laminated Plastic Sheet NEMA Grade C
Heat Exchanger Tube Trimming
11/25/2013 11:32 PM
hello,
my activity is to give a proposal for trimming the tubes in the heat exchanger. And my proposal is that "i will cut the tube ends after aligning it and i will do facing in it"
It will be ok or not?
Re: heat exchanger tube trimming
11/25/2013 11:42 PM
Not.
11/25/2013 11:49 PM
only tube facing will lead to good results?
11/26/2013 12:05 AM
What we have is faiure to communicate.
11/26/2013 12:32 AM
Sounds like you want to weld it from the inside!
If this sounds like a good proposal to you make it sound and sound it of!
Anonymous Poster #2
11/26/2013 1:14 AM
Anonymous Poster #2
11/26/2013 12:51 AM
Generally, you can cut extended length of your tube from tube sheet hole.After that you can remove the burr by facing or any other kind of machining operation to make the cut surface even.
What is the material spec. of tube??
Anonymous Poster (3); IdeaSmith (1); lyn (2)
