Previous in Forum: Kg/Cm2 (man)   Next in Forum: Pressure Vessels
9 comments
Hot Air Bleeding System Not Working Properly
11/27/2013 1:43 PM
In a WALKING BEAM FURNACE (Fuel: Natural Gas), HOT AIR should enter the furnace at Temp. = 450 ˚C.
There's a safety that if the incoming air Temp. is higher than 450 ˚C, the BLEEDING VALVE opens and releases all the hot air out before it enters to furnace zones.
The problem is: That bleeding system doesn't work properly although the bleeding valve is 95% open. After analyzing this problem, we found that there's a poor design for the piping after the bleeding valve downstream the chimney. Poor design is represented in sharp bending angles at two positions of the piping system (Bend angle = 90 ˚) which may obstacle the hot air flow to the chimney.
There's a suggestion to remove the welding at the two positions and re-weld again after correcting the bend angle.
Another suggestion is to install a small suction unit at the chimney to suck the hot air out.
Which of the two suggestions do you recommend? Why?
New suggestions are warmly Welcomed
Thank you.
Re: Hot Air Bleeding System not working properly
11/27/2013 1:47 PM
New problem, or old problem?
The suction unit would be the easiest/cheapest solution. If it works.
Otherwise re-pipe.
11/27/2013 1:59 PM
I can't judge if it new or old because we are in the 1st startup of the furnace.
You can consider it as an inherent problem maybe :)
11/27/2013 1:52 PM
Hint:
For the suction unit suggestion: The suction unit will not be continuously running. It will only work when bleeding valve opens (Hot Air Temp. > 450 ° C).
I mean that the cost will not be high as it's running continuously.
Re: Hot Air Bleeding System Not Working Properly
11/28/2013 4:22 AM
i dont know what i'm talking about - but is your valve (location+function correct)
fig. follows:
ci139
11/28/2013 11:46 AM
Sorry ci139, I didn't understand what you mean
11/29/2013 12:17 PM
that makes 2 of us (****i never designed any air systems) but :: if your hot air preffers a route to furnances instead of temperature control shaft (or was it to bleed the cool air in) - whatever the case i cannot evision your diagram providing a fast responce in eigher case - unless you set a blender hot off replaced by the amount of cool air - as i said - i donno what i'm talking****
ci139
11/29/2013 1:07 PM
in other words if you decrease your hot air pressure behind the bleed it's original temperature remains only the amount of heat transferred to furnances per unit time decreases - so your furnaces have likely "tremendous" heat capacitance the only way to tell the temperature will go down is to predict such by airflow temperature + (plus) "supply" flow speed - (minus) losses in furnance = indirectly (predictively) - if your sensor is in suply tract the only way to "set" it's reading (fast) is to beed in additional cooler air ((1-ce again i don't like to "advise" something i don't have no practical experience in))
ci139
12/03/2013 7:09 AM
trivia:[p/]
<*>. the designers of your heaters must know the required test procedures and their order incase of any malfunction
(1) incase you test with no load (no heat loss) in furnances test with it
(2) if your input airflow is too hot (for a valve to operate normally) adjust it
(3) if you have a sensor(/?controller)-network problem (reffer to <*>)
NB! - i just improvise here without any knowledge related to your design nor metallurgy proceses in general - you have to think yourself - good luck!
ci139
12/03/2013 2:18 PM
ok, thanks ci139 for your comments
Register to Reply 9 comments
ci139 (4); lyn (1); mohamedminem (4)
