Previous in Forum: Software for USBscope50 Not Working --- Java?   Next in Forum: Windows 7 Is Driving Me Crazy
Missing Dll File System Error
12/04/2013 7:24 AM
Hi,
On every computer startup, I get system error message followed by .dll file missing message. Everytime, a new dll file missing is shown. I tried dll file fixer support, but it onle works one br one. My OS is windows 8. Can sb help?
Regs,
sks
Re: Missing Dll File System Error
12/04/2013 7:46 AM
12/04/2013 9:08 AM
I would do a registry update....
12/04/2013 1:12 PM
if you have the full dll file name you can search for it on any other W8 and copy it to a stick. Note where the search found the file and copy it into the same location on the bad OS directory. Reboot and look for another dll message, these usually take out more than one at a time. Repeat the process as necessary and when you have no further errors do a windows update fom MS.
12/05/2013 6:25 AM
If the steps Kram has posted do not work then you have a hardware problem, such as a bad hard drive or what I think may be the case, a bad SSD drive. Hard drives lose data from time to time, particularly in the boot sectors, but rarely do the missing dll's change with each restart. But a flaky SSD might actually do just that since the memory allocation is quite different from a conventional hard drive. Please let us know what you find.
My shoes are too tight, but it doesn't matter because I have forgotten how to dance.
Good Answers: 122
12/05/2013 8:44 AM
When was the last time you defragged your hard drive?
If it has been more than a week and you access the internet a lot, I would suggest doing so then see if the problem goes away.
12/05/2013 9:46 AM
I have never defraged my drives since they got to 500 G. As long as you have plenty of disk space the OS does not need to fragment even the largest files if it can find enough contiguous space. I typically have several hundred gigs of free space. If you routinely defrag your disks you could incur some slight corruption since there is no attempt to verify that the file was copied correctly.
12/05/2013 11:19 PM
thanks for suggestions. I will take care of them.
Regs,
Sks
aDIYguy (1); kramarat (1); LongintheTooth (1); OldTooly (1); sauravbabu (1); SHOCKHISCAN (1); SolarEagle (1)
