Previous in Forum: Overcurrent Coordination Between TRF Primary and Secondary Relays   Next in Forum: O/L Relay in Star-Delta Starer
Clearance Between MV Motors and Concrete Structure
12/09/2013 8:24 AM
Is there is any standard which tell about the clearance between mv motors and concrete structre. please give a reply. Or otherwise is there is any minimum clearance is needed between mv motor and concrete structre
Good Answers: 140
Re: Clearance Between MV Motors and Concrete Structure
12/09/2013 9:48 AM
You have to wonder... how many times does one have to say this...
Check your locally adopted code!
In my jurisdiction, a minimum of 1 meter of clearence is required around all electrical equipment to allow for maintenance. I expect the code in effect where you are installing this, if it is worth anything, will have similar requirements.
Good Answers: 42
12/09/2013 10:06 AM
In my opinion, the motor location is dictated by the driven object [or installation] position. The motor specification has to include the position of the terminal box-in the opposite side of a wall and you have to consider the working space in front of the box according to the local code-NESC, BS, NF, DIN/VDE or else. For instance, horizontal clearance from the terminal live parts-when the box door is open for maintenance , even if the supply breaker is open but before checking the voltage missing and short-circuiting and grounding the living parts-has to be 1.02 m for 7.2 kV [NESC Rule 124 Table 124-1].
Julius
Good Answers: 804
12/09/2013 10:09 AM
In many installations I have been involved with, the minimum clearance to a concrete structure is zero, if you are looking at the concrete it is mounted to...
12/09/2013 11:00 AM
42
12/09/2013 11:07 AM
There probably is a standard for your location and the motor you are using to move something.
Now look carefully at the answer I just provided. There are three attributes I identified. I am not sure if these are the only attributes needed to solve your problem but you do not provide us even the details about these three attributes.
Go fish.
Register to Reply 6 comments
7anoter4 (1); JRaef (1); lyn (1); North of 60 (1); redfred (2)
