Previous in Forum: Heat Treatment   Next in Forum: Function Test
Nut Heat Treatment Process
12/21/2013 11:48 PM
Hi,
could any one provide me a procedureof heat treatment of the following,
ASTM A194-A194M -Grade -2H, 2H , 2HM , 4, 7,7M,8, 8A, 8M, 8MA ,
ASTM Stnd. A563 - Grade -A , B , C, DH
ASTM Stnd A563M - Grade -10S
thanks,
Re: Nut heat treatment process
12/22/2013 12:06 AM
Yes, Milo can.
Maybe you can PM him.
Re: Nut Heat Treatment Process
12/23/2013 6:34 AM
I am ready to help you out provided you send me the actual chemical composition of these materials as I do not remember the composition of these ASTM numbers.
Good Answers: 34
12/25/2013 6:33 AM
MECHANICAL PROPORTIES
Grade Identification Marking 5
Specification
Material
Nominal Size, In.
Tempering Temp. °F
Proof Load Stress, ksi
Hardness Rockwell
See Note
Min
Max
ASTM A194 Grade 2Medium Carbon Steel1/4 - 410001501593521,2,3
ASTM A194 Grade 2HMedium Carbon Steel, Quenched and Tempered1/4 - 41000175C24C381,2
ASTM A194 Grade 2HMMedium Carbon Steel, Quenched and Tempered1/4 - 410001501592371,2,3
ASTM A194 Grade 4Medium Carbon Alloy Steel, Quenched and Tempered1/4 - 41100175C24C381,2
ASTM A194 Grade 7Medium Carbon Alloy Steel, Quenched and Tempered1/4 - 41100175C24C381,2
ASTM A194 Grade 7MMedium Carbon Alloy Steel, Quenched and Tempered1/4 - 411001501592371,2,3
ASTM A194 Grade 8Stainless AISI 3041/4 - 4-801263004
ASTM A194 Grade 8MStainless AISI 3161/4 - 4-801263004
NOTES
• The markings shown for all grades of A194 nuts are for cold formed and hot forged nuts. When nuts are machined from bar stock, the nut must additionally be marked with the letter 'B'. The letters H and M indicate heat treated nuts.
12/25/2013 6:46 AM
HI,
thaks for your reply but i required the heat treatment detailed procedrue that how to make the nut of above ASTM and grades,
Good Answers: 34
12/24/2013 11:02 AM
All these Materials are P1. You have the parameters mandatories in ASME I, ASME IX, and also in ASME B31.1 and B31.3.
Wich one are you using?
12/24/2013 11:19 PM
i can provide the ASTM standard but heat treatment procedure detailed required if any one know plz help ... you may give me your email so i will send it,
thanks,
12/25/2013 5:46 AM
Kindly send all the details about the materials. I will give the heat treatment schedule.
CR4 Admin - removed email address
Register to Reply 7 comments
lyn (1); mhdzeeshan (2); viswa1945 (2); Whitephone (2)
