Previous in Forum: "5IK40GN-A" Oriental Motor Induction Motor: Wiring Diagram   Next in Forum: Transmission Line Spring Constant/Stiffness Coefficient
Jotacote Universal Top Coat Paint
12/22/2013 9:41 PM
Dear friends,
I am going to paint Inside surface of a steel pen-stock which is feeding a 50MW Pelton runner hydro power station.
Contractors have given two options regarding painting.
1. Sigmacover 300
2. Jotacote Universal
Which is the best paint as a top coat? Please give your opinion.
Tilan
Re: Jotacote universal
12/22/2013 10:08 PM
Well,
"Jotacote Universal is a primer.
The basic concept of a universal primer
is its suitability as the main primer
virtually all round the vessel.
Jotacote Universal meets the
requirements for an all round* primer"
Jotacote Universal
Sigmacover 300 is a top coat.
"SIGMACOVER 300 steel with approved shop primer; power tool cleaned to SPSS-Pt2 or. •. SPSS-Pt3 existing coal tar epoxy ..."
sigmacover 300 - SigmaCoatings - Marine and Protective Coatings
Look at the data sheets.
Good Answers: 104
Re: Jotacote Universal Top Coat Paint
12/22/2013 10:57 PM
You don't say whether this is a new or existing installation.
1. Consult with the manufacturer that this is an appropriate coating, and what is the guarantee?
2. If previously coated, ensure that the old coating is compatible with the new.
3. Ensure that any surface preparation is properly carried out.
4. Since you are coating the inside of the pipe, make sure that the surface can be walked on within the time allotted for a second or top coat.
12/23/2013 12:09 AM
I would blast it to spec and use the Sigmacover 300 2 part epoxy as a top coat....
12/23/2013 9:47 AM
Jota...Recommended use
A universal primer specifically designed for use in newbuilding situations. To be used on steel alone or in combination
with various systems. If a cosmetic finish is required, it should be used together with a topcoat. so this shouldn't be considered as a topcoat.
12/23/2013 10:04 PM
Dear all,
Thanks for your comments. Yes I am going to to power tooled the corroded places to St 3 and apply a top coat following a primer and other places will be roughen and coated with suitable coal tar epoxy. This was originally coated by Coal Tar coating following a primer.
bigg (1); Fredski (1); lyn (1); SolarEagle (1); Tilan (1)
