Previous in Forum: Minimum Distance Between Pipe Fittings   Next in Forum: Equivalent Indian Standards to Chinese Standards
8 comments
Engineering Fields - Mechanical Engineering - I am here to help!!
Case Carburizing of EN8 or BS970 080M40
01/19/2014 11:22 PM
Is it possible to case carburize EN8 or BS970-080M40 to get surface hardness of 60 Hrc?
Re: Case Carburizing of EN8 or BS970 080M40
01/20/2014 11:18 AM
Where have you looked so far?
OSMB Technical Handbook Iss3.pdf - OneSteel
Canada - Member - New Member
01/21/2014 12:29 AM
hi lyn - this is rabbit 16 lurking in the backround. i want to thank for the very usefull links that you have provided over the years to answer peoples questions. for me they have been quite usefull.
where is my pencil?
01/21/2014 10:53 PM
Actually I already found that Handbook but I didnt read it as I thought its just about material chemical composition. But, after you suggested I went through it and found the answer.
Thanks very much.
Actually I wanted to have strength of En8 and localized surface hardnes of 60 Hrs to 0.5mm depth.
But, now I think I should rather go for EN36 or 655M13
Good Answers: 117
01/22/2014 9:29 AM
Good choices. Check prices though.
Good Answers: 183
01/20/2014 6:22 PM
If you look in special books you will see that if C>0.3-0.35% carburizing is not recommended for different reasons. Both steels are over the limit.
01/20/2014 11:11 PM
Instead of carburising, you may go for quenching of steel EN8 after heating to a temperature of 820-860 degree C and quench in oil or water. Tempering is required after quenching.
Good Answers: 183
01/21/2014 6:32 AM
Do you expect with so little carbon to obtain the reqired hardness ? If you already did it give the secret since till now it was never possible.
I very much appreciate when counsels are done after reading FULLY the request and UNDERSTANDING it.
Good Answers: 117
01/21/2014 5:29 PM
This link explains how to surface harden EN-8
Register to Reply 8 comments
IRSHAD (1); lyn (1); nick name (2); pc (1); rabbit16 (1); Yusef1 (2)
