Previous in Forum: Oven Air Flow Requirement   Next in Forum: Calculating Root Area for Bolt
10 comments
Frequent Idler Failures - What To Do?
01/25/2014 10:14 PM
Hi, We are experiencing quite frequent Conveyor Idler failures. We are a Iron Ore mine site, using 1800mm Steel cord belt and throughput rates are 4000TPH.
The failures are mainly observed at a stacker head where the Ore is dropped to the stockpile and carryback get accumulated on the return roller. We observe a collapsed return roller every week with material build up on it. We are using Sandvik Steel Rollers.
We used H type scraper at the head end however, the Maintenance of this scraper is an issue due to the access problems. We dont have any platform at the stacker head to adjust the middle blades so a visible gap developed between the blade and belt. We have 2 more scrapers but carrybacks are terrible. Any suggestions on how we can control the carrybacks or a different type of Roller we can use to alleviate failures???
Thanks
Re: Frequent Idler Failures,,, what to do?
01/25/2014 10:40 PM
01/25/2014 11:25 PM
Good Answers: 141
01/26/2014 12:04 AM
Problem points need easy access, in your case to keep the belt clean. As I see it, you are using a steel wire enforced rubber belt? Probably subject to damaged spots and sticky residue at the end roller.
The maintenance of the belt cleaning should be done on a roller. In your case the end roller before the idler gets involved.
I suggest you apply a rotating steel brush that counter rotates over the whole width of the end roller. It requires only a extra support and can be driven from the same shaft of the end roller (provided that the shaft turns and not the cylinder over a static shaft) At the end roller, the rubber is stretched in the good direction to clean the belt.
by 2 chain sprockets and a chain with a good cover protection and a exhaust for dirt, captured on the sprockets. If you want more details PM me please.
Plenty of room here
01/26/2014 1:58 AM
Thanks Guys for the help, I will look into details of Martin Engg as Im located in Australia.
Can you please provide more details of Steel brush which cleans right after the head pulley? Our head pulley is 1200mm and I assume you are saying we connect the wire brush to the shaft of Head Pulley for cleaning??
Cheers
Good Answers: 141
01/26/2014 8:35 AM
Yes, put a sprocket on the shaft of the end roller and order a brush with a solid shaft and put a sprocket on there too.
Depending on the width and speed, use 3/4" bigger chain or bigger. You can work many ways:
1. Bigger diameter brush and e.g. same sprockets.
or
2. big diameter sprocket on belt shaft and smaller on brush
In both cases the brush will rotate faster (contact speed) than the belt = better cleaning. The brush will also rotate against the belt direction on the way back.
Provide the proper bearings for the shaft.
Check here for an idea- Australia will have providers too:
http://www.spiralbrushes.com/cylinder.html (copy and paste)
Best regards. D
Plenty of room here
Good Answers: 141
01/27/2014 9:09 PM
I have worked with conveyor belts of all kind. The first idler is actually a placed there to get more contact surface between the belt and the roller. Because of its relatively small diameter and the pressure it has to take, this roller is the first to break down when deposits leftovers: or get stuck or adhere and make the diameter of this roller bigger and most of the time not equally.
A difficult product is sticky gum (mixture of kelrez, calcium, esters, water and emulsifiers) - and the brush works even for that.
Your ore is in no way more sticky, even mixed with clay. What brings us to clay quarries for clay bricks. They use these rollers too. It don't care what nut professor stripped the good answer(s). However I see no alternative brought here.
If you need more info PM me. I give non commercial advise. Regards. D.
Plenty of room here
Re: Frequent Idler Failures - What To Do?
01/27/2014 2:58 AM
Hi, I am at present doing an observation and solutions project for a number of clients who have cleaning issues and severe roll failure issues.
Please check our website http://www.ci-int.com and contact me on my email
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers and email addresses posted in threads or comments. You can share this information via the CR4 internal messaging system.
and I will discuss your issues and some possible solutions.
Contrary to what many think, the best exponents in the Bulk Materials Handling Systems are all failing to see the real issues due to pre-conceived outcome solutions.
My proprietary VitreSteel OneFits Rolls which have the greatest load carrying capacity and wear longevity for any particular diameter in the industry and are lasting 3 to 13 times longer than the best of all the other manufacturers' rolls. The OneFits Rolls still fail but Fail to Safe without becoming a 'Pizza Cutter', This has been estimated by the mine optimization engineer.
Hope this will give you some real solution to work with as I am prepared to assist and I will be putting this observation report to a white paper in the future.
Les
Mechanical Solutions Company where 'There is no such thing as a PROBLEM, just an ISSUE requiring a SOLUTION'.
01/27/2014 3:23 AM
In my limited experience (sand and gravel) with belt conveyors the large head (drive) drum is too large to break the 'stiction' with the material. Two small rollers beneath, one below and one above the belt to put a gentle kink into the belt path will help considerably. That first roller (one the material side) should not be a simple tube, add bars to the O/D to put some vibration into the belt.
This generates another issue of course, all the shed material falls beneath the conveyor and reasonable access is required to clean up.
01/27/2014 4:15 AM
Hi, Whilst I know that you have a solution, remember that using a pulley or roller with too small a diameter will flex the belting beyond its limits and 'Break' the carcass and this will result in a larger issue to deal with and belting generally forms between 40% to 50% of the total cost of the conveyor. Small radius pulleys or rollers than the required terminal pulley's diameter must have less than 2% 'Angle of Wrap' to prevent carcass damage.
Just a small comment that can be found in the belt manufacturers recommendations and the best general guide being CEMA 'Belt Conveyors for Materials Handling'.
01/27/2014 7:31 AM
Sir, the area of the conveyor is tail pulley bearing or idler rollers which i doubt. The main cause which i doubt is failure of the tail pulley bearing or the failure of idler rollers, for both we have a solution. In the mines basically the problem is contamination ingression into the rolling or moving parts. if the issue is that i can definitely help you out. If possible please provide some application facing problem site pics, so that it would be more clear at my end.
Thanks & Regards,
Debjyoti Bhattacharjee.
Anonymous Poster (1); deb123 (1); dvmdsc (3); Eleven (1); SolarEagle (2); tecmate (2)
