Agreed...no!....now for why (from personal experience):
As you weld, you melt the base metal and add filler right? What happens to that zinc coating? It doesn't all burn off. Most actually is melted along with the base metal and then alloys with it changing the properties local to the weld. In most cases creating a weak boundary at the weld-base metal interface.
The zinc coating that actually does burn off creates highly toxic fumes, that you REALLY don't need to be breathing.
If you don't have time to do it right the first time, when are you going to have time to do it over?
Remove by grinding, deburring tool, file or machining.
If you breathe the gases of the burning zinc (even surrounding zinc after removal) you will feel quite ill. If this happens, drink about a liter of milk. I've found it's the only thing that helps a bit.
In my many years I have come to a conclusion that one useless man is a shame, two is a law firm, and three or more is a congress. - John Adams
I'm not knocking 'old school' at all, I was just wondering if the treatment was genuine, or something like an urban myth. The link backs up the treatment, but still, I'd like to know why?
'The truth is out there' The lies are in your head.
Yes, You can do welding on galvanised areas as long as it is in open. There will not be much of a health problem. If required use portable exhaust fans.
If required , use cup wire brushe with 4" AG-4 (or) stringer brush with GQ-4 grinding machines ( available at all Industral hardware stores in India) for cleaning.
Use E 6010, E 6013 for SMAW or ER 70S-6 for MAG/Co2 welding Processes. Paint it back ( zinc) after welding. We have done lot of pipes with good results and still ( more than 12 months ) in use .
The zinc coating is vaporized if you breathe it in the zinc gets into your bloodstream. You get enough of it in your lungs your lungs can react adversely depending on your sensitivity to the zinc and other by products. Basically it can kill you. I used to arc weld and had a ton of zinc coated scrap metal available. I would hold my breath during the weld and flip my hood up walking away and then breathing. Then chip the slag and put another stick in the handle and start again holding my breath at first arc. Did that safely for years.
Safety got on my case and told me I had to wear a respirator. They gave me the respirator set up with an organic filter. The safety guy didn't understand the differences in filters and set me up with a nearly fatal accident. With an organic filter on it, the mask worked great on the smelly fumes but did not stop the zinc metal gases. I couldn't taste it as I breathed it in. Before long I ended up in the emergency room. Zinc metal in the body has a half life. It takes a very long time for the body to rid the metal from your system. It effects the nerves some. The only real cure is time.
Use HCL acid to clean the zinc out of the base metal. That will solve the problem of toxic fumes ( deburring and other processes will leave some residue but HCL will not leave any)
