Previous in Forum: Dual Inlet Separators!   Next in Forum: Electrolysis
Heat Exchanger Design
06/12/2007 1:55 PM
product entering the tube side of a shell and tube heat exchanger at 40 degrees. it is desired to cool this product to 20 degrees using chilled water at 5 degrees.
how do i calculate the outlet chilled water temperature. i am given the specific heat capacities and mass flow rate. i want to design this shell and tube heat exchanger.
thanx
sarika
Re: Heat Exchanger Design
06/12/2007 2:40 PM
I would suggest applying the 1st law of Thermo for a control volume.
[ h + 1/2v +gh ]inlet (for each fluid) + Heat(Q) = [ h + 1/2v + gh ]exit (for each fluid) + Work
Also, you must make a few assumptions: - No work(incompressible liquid), No change in velocity, no change in potential. Also if you take your system to be around both pipes and assume no heatloss then Q=0. Therefore you are left with,
m1*[h1]i + m2*[h2]i = m1*[h1]e + m2*[h2]e; now if you have some sort of table, then use that. If not, /\ (change) h = m*cp/\(Temp):
Solve for T2 of water.
06/13/2007 7:55 AM
Use the following formula to calculate the chilled water outlet temperature Toutlet in degree Celcius:
M1 x Cp1 x ((273 + 40) - (273 + 20)) = M2 x Cp2 x ((273 + Toutlet) - (273 + 5))
M1 = Product mass flow rate in kg/hr
Cp1 = Product Heat Capacity, Kcal/kg.degree Kelvin
Make sure that you have the correct units.
Good Answers: 183
06/13/2007 12:32 PM
Since the K°=°C it is not necessary to refer to the absolute zero. The equation can be solved in °C only
06/13/2007 2:53 PM
if both of the flow rate were known the answer is straight forward by using equation:
Energy balance: Q=mhCph(Thin-Thout)=mcCpc(Tcout-Tcin)
But for this type of problem, usually only one of the flow rates is known. Therefore iteration is required.
Calculation requires tables and charts, but basically there are 2 equations that u should use:
Q=mhCph(Thin-Thout)=mcCpc(Tcout-Tcin) and Q=UA F(LMTD);
F is the thermal correction factor and LMTD is the log mean temperature difference.
correction factor F will determine the type of S&T HE to be used (i.e single pass or multiple pass).
first u should determine/assume the unknown flow rate. Using the 1st equation u will obtain Temp. outlet of the product.
Temp outlet from the first equation is used to obtain Q from the 2nd equation This is where the table and charts come into play, which is to determine U,A and F.
From this point on u should iterate until the Q from the 1st equation is approximately equal to the Q from the 2nd equation. Tout questioned is the Tout that makes this condition possible.
good luck.
Register to Reply 4 comments
Anonymous Poster (2); navy_blu (1); nick name (1)
