Previous in Forum: Vane Wheel   Next in Forum: Thickness of Rectangular Tubesheet
EN 13480-3 Calculating the Wall Thickness of a Reducer
03/21/2014 10:30 AM
I am trying to calculate the minimum thickness of a conical reducer (econ) according to EN13480-3 which is equation 6.4.4-1 which states econ = (pc x De)/(2f z-P) x 1/cos alpha, however from what I can see it does not state what the variable P is. Does anybody know what the variable P is ?
Re: EN 13480-3 Calculating the wall thickness of a reducer
03/21/2014 10:43 AM
Pressure. Exactly which pressure, I've no idea.
03/21/2014 10:49 AM
I presumed it was Pressure alright but as you said I have no idea which pressure it is. Do you know if you multiply to 2f by z - P on the bottom line ?
03/21/2014 10:59 AM
Sorry, can't tell. These are some of the most ambiguous equations I've ever seen!
For the benefit of others:
I assume it's (PDi/2f(z-P))x(1/cosα), but your guess is as good as mine!
03/21/2014 11:22 AM
I have the 2013 edition and it is slightly different to the equation that you just posted. It has pc on the top line which is calculated pressure and then just P on the bottom line, it is P which I don't know.
Register to Reply 4 comments
