I found this document, and as far as I can tell it is accurate. Although it skips some steps it appears to me that the final equation (Highlighted in Yellow) does correctly solve for 'D' (Note 'D' and 'd' are different)
Luckily my task (this is not homework) is to measure 'h' and then calculate 'D'-- For this topic we will say that rd=12inches and 'd'=27inches (both bottom rolls same radius + 3inch gap between them)
Problem is when 'h'=0 I would expect D=0 also --- this is not the case--Why?
