Previous in Forum: What's the Difference Between a Bolt and a Screw?   Next in Forum: Electro-Magnetic Gripper Design Problems
10 comments
Adhesive for Rubber and Stainless Steel
06/13/2007 12:52 AM
Which is the best adhesive to stick rubber on Stainless Steel 316.
Popular Science - Weaponology - New Member Hobbies - Musician - New Member
Re: Adhesive for Rubber and Stainless Steel
06/13/2007 9:05 AM
06/13/2007 9:21 AM
Bostik "Boscoprene" cement 2402 is suitable for bonding rubber to steel. Bostik "Boscolite" primer 9252 is first applied to the steel and allowed to dry. The manufacturer should be able to advise if it is specifically suited for 316 SS.
"correct me if I'm wrong, but hasn't the fine line between sanity and madness gotten finer?" - George Price
08/14/2009 1:39 PM
you are @#$%^&*!~#$%^&*@#$^@...........
Location: Idaho Springs, CO, Capulin, NM, Roberts Creek, British Columbia
06/14/2007 1:18 AM
You might try a tube of polyurethane sealant/adhesive for about 4 bucks. That stuff can be mighty amazing
cavitywall
06/14/2007 8:55 AM
3M brand 5200 glue/sealant works excellent.
06/14/2007 9:52 AM
bostich,partialy vulced rubber resin,anyway etch,sandblastor phosphatise to creat a good ancher.have you inherited this ss316 item
06/14/2007 10:24 AM
Rubber compounders are a special breed of chemist... turning the raw slime into everything from bands that will stretch 20 or more times their relaxed length, to seals that withstand enormous pressures and chemical attack, to tires that roll for scores-of-thousands of miles, to rocket propellant! The Master of bonding rubber(s) to metal was ... believe-it-or-not ... (Mr.) Lord. Lord Corporation (Erie, PA) grew out of the need for rubber-to-metal engine mounts, to help our military machinery last a bit longer than it was (way-back-when). The company has evolved (joining with Hughson Chemical, among other advancements) ... and can provide a wealth of decades worth of knowledge. Visit: http://www.lord.com/
What kind of rubber are you trying to bond, and what kind of adhesion strength are you seeking?
United Kingdom - Member -
06/15/2007 2:09 AM
You might try Goodyear Pliobond. The company I work for has used this for years to bond rubber to all kinds of metals including Stainless Steel.
Drew
06/15/2007 11:27 AM
Are you trying to vulcanize the rubber and at the same time adhere to the stainless?
If so, grit blast the surface of the SS, (keep it clean) apply Chemloc 205 as the primer coat. When dry apply Chemloc 220 and allow to dry before molding, this works with most rubbers- Natural, SBR ,Nitrile, excluding Silicones. Other Chemloc products include 250, 252X, 6254 all have proved good.
If trying to adhere pre-vulcanized rubber to SS it would still be best to grit blast the surface first to create more surface area for the adhesive. DAP Weldwood Contact Cement works good in non-critical applications especially on flat surfaces. Also check 3M's web site for your application.
06/17/2007 12:45 AM
Thanks for the help.
ad016 (1); Anonymous Poster (5); cavitywall (1); Kuchroo (1); steve-o (1); The Jacket (1)
