Previous in Forum: NER Body Termination And Cable Sizing   Next in Forum: DG Generator Unable to Run Machines
15 comments
Materials of Earthing Network
04/15/2014 1:52 AM
Can anybody well aware on the subject advise me haw to select the suitable materials ( i.e.copper , galvanized metal , stainless steel copper coated .....etc. ) of the tapes . rods , bare cables ....etc that are to be used in implementation of Earthing / Grounding networks according to nature of ground soil?thanks in advance
Re: Materials of Earthing Network
04/15/2014 1:56 AM
No.
04/15/2014 2:08 AM
I can't understand?Do you answer on behalf of the others?
04/15/2014 2:11 AM
No.
04/15/2014 10:51 PM
I vote 1 for GA
No location, No detail, No answer cannot be provided accurately
04/15/2014 2:16 AM
Good Answers: 131
04/15/2014 11:39 AM
Most grounding materials sold by reputable manufacturers for the purpose of constructing a ground grid, such as copper-clad steel rods or solid copper conductors, are designed to be applicable to the broad range of soil conditions found in most localities. It is seldom that you have to stray from standard materials for this reason.
What might be more helpful to you is to understand what it is about the soil that can make proper grounding so challenging, and how the grounding conditions can be measured and tested. Check out the following link for a very useful PDF resource from Megger on this subject:
GettingDownToEarth.pdf
04/15/2014 10:58 PM
Go though lightning protection and earthing products manufacturers like FURSE etc
pnaban
Good Answers: 102
04/15/2014 11:46 PM
Did you post anonymously by accident? Ask again with an identity.
04/16/2014 12:09 AM
It is difficult to specify answer pointwise as it may need a chapter to be written. SO I am trying to provide some insight into the subject. The points considered are -
  1. Conductivity needed - This palays role in decision of material.
  2. The cost - which limits both material and shape.
  3. Location - plays role in deciding shape of material.
  4. Specific Purpose i.e earthing what?? Plays role in deciding in materials specs.
In tall metallic structures the structures themselves work as down conductors up to two meters above the ground, provided they are 4mm + thick.
Where you need to open frequently and might get handled/twisted i.e. where flexibility of earth connection is needed ... for example say welding sites , floating roof tank ( pontoon tanks) in petroleum installations etc - the earth connection is a wire or a cable - wire for steel and cable for copper. In software it could be braided copper strip - say flat cable type.
Gi / copper strips can be laid in side the ground or along some surface/ structure if high current passage is expected. GI plays role for strength as well . Where network length is more GI may do and for very short lengths Copper may be better.
There could be innumerous considerations like this . you may dwell further for the topic elsewhere on net.
Let us discuss the practical issues not the classroom.
04/16/2014 6:52 AM
Refer BS 6651 or IEC 60325
pnaban
04/16/2014 4:50 AM
Welcome to Planet Earth Anonymous 1. We on planet earth have a system known as GOOGLE, which most earth bound beings use, on a daily basis for searching for answers. We have beings known as Students, who use this for homework answers and others known as researchers who use Google for researching topics.
As for earthing materials I have found, from experience, a good quality length of wet string, a six inch nail and a damp sponge is of absolutely no use for earthing, however it can be used anywhere and is quite versatile. Easily transported by magic spoons and gnomes.
I also agree with Lyn. No.
Good Answers: 117
04/16/2014 6:09 AM
Need a name. Otherwise you are, um.... anonymous. And deserve no answers.
04/16/2014 6:13 AM
NO NEED !
Reply Off Topic (Score 6)
Good Answers: 102
04/16/2014 6:29 AM
That is an excellent name! Use that one.
Reply Off Topic (Score 3)
05/16/2014 2:53 AM
It has been often found that most of think that material used for earthing will reduce earthing resistance.
It has been often misconception that copper earthing plate or rod will have lower earth pit resistance then GI earthing plate or rod.
Earthing will not depend on type of material used for earthing for details visit
http://electrialstandards.blogspot.com/2014/04/is-copper-as-earth-pit-is-better-then.html
Reply to Forum Thread 15 comments
Anonymous Poster (2); gckent (1); IQ (1); lyn (3); M.R.Iyengar (1); navdeep_goyal (1); PeterT (1); pnaban (2); Wal (2); Yusef1 (1)
