Previous in Forum: What is CCNA?   Next in Forum: Radiation from Microwave Ovens
9 comments
Hole in caravan water tank
06/14/2007 12:47 AM
What can I use to fix a hole in a black hard plastic water tank for a caravan
Re: Hole in caravan water tank
06/14/2007 4:37 AM
I fixed a split water tank with a hot knife, melting the spilt together again! Or a good glue might work!
Good Answers: 21
06/14/2007 4:59 AM
Not sure what the tank is made from. It sounds as if it's PP (polypropelene) in which cas it can be heat welded with a rod of PP or maybe just heated up and pushed together as it's a thermoplastic. PP cannot be glued.
Good Answers: 101
06/15/2007 12:20 AM
How big is the hole? If it's small, you can use epoxy putty to patch it up. If it's big, you'll probably have to use a piece of the same material to cover the hole before sealing it.
Location: South East of Las Vegas just far enough to see the lights but far enough to not hear the coins falling
06/15/2007 12:30 AM
go to your nearest Ferguson plumbing supply house they have a two part epoxey the will work with very little prep.
Rule number one; Never ask a question unless you are prepared for an answer that you may not like.
06/15/2007 12:37 AM
Drill an perfect hole just in the hole. Thread it and put an Stainless screw.
06/15/2007 12:58 AM
Use a small electric soldering iron & a scrap piece of PP & "Solder" / melt the crack or hole together again, don't breathe the fumes given off when doing it, also determine why it cracked or was holed in the first place & attend to that first !! badly mounted, holed by a stone or tree stick driving on a bush track ?? might need remounting or a light metal protection plate mounted under the tank.
Brien
06/15/2007 5:56 AM
Make sure the inside of the tank is completely dry and as warm as possible, (a hair dryer carefully aimed into the filler hole will do the trick). Clean any dirt from around the hole and warm/dry this area too. Apply 2-part epoxy resin to the hole and surrounding area, (fast-setting Aradite is best).
Then the trick is to squeeze the tank while you screw the lid on. When you stop squeezing there will be a slightly lower pressure inside the tank and the resin will be sucked/pushed further into the hole and into the tank.
If you gently warm the repair area the resin will flow better, set more quickly and leave a flatter contour on the outside of the tank.
This method also works for fuel tanks and central heating radiators,(use Metal/epoxy araldite).
Good luck
06/15/2007 12:07 PM
If ther is a salvage yard(junk yard) available to you, just get a used one!
06/15/2007 12:56 PM
What? No duct tape?
If all else fails, read the directions. That's if, and only if.
Anonymous Poster (2); DVader1000 (1); ktel60 (1); Langdom (1); MACA (1); miketheboilerguy (1); Mr. Truman Brain (1); tom (1)
